Help with the creation of an optical configurator for a custom integration
Hello Community
I am currently building my first Home Assitant Custom Intigration/Custom Component and have finished it so far, but I noticed during testing that I can not add it to Home Assitant, because home assitant tells me that the integration can not be configured visually but only via the Yaml .
My integration is only designed for optical configuration but not for yaml configuration and I have already looked through my code (or rather looked through my config_flow) and compared it with this example of a config flow (the integration from which I have the config_flow as an example, can be added visually without any problems) here.
I didn’t really notice anything during the comparison and there is nothing in the home assistant logs either. I just get the message that this integration can only be configured via yaml.
Do any of you have an idea what I am doing wrong here?
There are a few things wrong here but the thing giving you the error is that you are missing…
config_flow": true,
in your manifest.json.
You also need to create a translation(s) file to display it correctly. See the translations folder on the example you are copying.
Thank you so much it worked
