I installed the generic hygrostat with HACS and up my binary sensor as follows:
binary_sensor:
- platform: generic_hygrostat
name: Bathroom Hygrostat
sensor: sensor.bill_br_govee5075_humidity # Source humidity sensor
delta_trigger: 3 # Optional humidity swing to detect. Default = 3
target_offset: 3 # Optional dehumidification target offset. Default = 3
min_on_time: 300 # Optional min on time in seconds. Default = 0 seconds
max_on_time: 1800 # Optional safety max on time in seconds. Default = 7200 seconds
sample_interval: 30 # Optional time between taking humidity samples in seconds, default 300 seconds
min_humidity: 45 # Optional minimum humidity to enable dehumidification. Default = 0
unique_id: bill_bathroom_hygrostat # Optional ID that uniquely identifies this sensor. Set this to a unique value to allow customization through the UI
No errors in HA, but I am getting null values for items in the sensors:
Not sure what I have done incorrectly? I followed the directions here:
https://github.com/basschipper/homeassistant-generic-hygrostat
Does this integration still work in Home Assistant?
