actually i didn’t work properly, the worse is that all last week it reported 100% humidity and the temp was ok… now nothing…
I am thinking about trying to interface it with a adc/i2c to get more precise and better readings maybe, but im unsure how to actually interface it. on the products tag there was this written on it:
SDA:grn/blu vcc:red sck:ylw/wht and gnd:blk as i mentionned earlier in my post, but i have this adc and i am not sure how to interface it with the sensor and my esp32s 38 pin
would i connect the sensor to the adc then the adc to the esp 32 using Dout or something?
thanks again for your help. I am constantly learning new shit and i like it!
ads1118 is the info i have but i do not understand the wiring that i would be doing?
have you looked at the ADC i specified? its got really different pins than the ads1115 so i’m not sure how to connect from the ADC (cjmcu 1x18) to my esp32s, i mean i dont know which pins to use from it to the esp32,is it the Dout ( which i am guessing is a digital out)
i’ll tell you what i think:
sensor sda to cs of adc
sensor sck to scl of adc
sensor vcc to vcc
sensor grnd to grnd
adc din to one of the digital gpio of the esp32s.
adc vcc #2 to vcc esp32s
adc grnd#2 to grnd esp32s
The ads1118 and are the same family from texas instrument. But they are using different interfaces. https://forums.adafruit.com/viewtopic.php?f=8&t=85573
The ads1118 uses spi and the ads1115 uses i2c.
So the library for the ads1115 does not work.
There are library out there to communicate with it but it will require you to write a custom component for that. Which need some programming skill and time.
Why do you say this i am complicating things, i just ask which pins i should connect the ads output to… what is complicating things in that question?
I am asking for help because after having tried by myself, i havent been able to make it work, so I come here for help!?
I just dont know where to get the info i need to make them work together, again, im a beginner in programming and HA, I am a digital colourist not a programmer, so i need all the help i can find hence me asking questions!
i have time but not that many programming skills, if you could help i’would be forever grateful!
If you can’t it’s okay too, i’ll keep my search, i’ll end up learning how to eventually!
I know that i don’t NEED one, i want to try this because i get bad readings from the sensor, so i want to try something that could get better readings, as it’s written in my initial post
I do not fully understand what i2c is or does, i am simply looking for solutions to my problem, i am not a cofder or have nearlyh any coding experience at all, i started with HA 1 year ago and this was my first time really starting to learn some real code. i self teach myself by reading and trying and making mistakes. so… i have no idea what i2c would do appart that the analog readings have way more resolution when used on a ads 1115 or 1118. i am told. but i dont even know why appart that it’s 16 bits…
I really sugest you study some microcontroller tutorials - there are plenty online. I have found this site good, although for a complete learner I am not sure how good it is, see if it suits you https://randomnerdtutorials.com/
I agree with @nickrout that it seems that maybe the humidity part broken. If the digital temperature is working then the digital communications is working then the analog probably not going to solve your problem.
Have you tried to dry it. Maybe it wasn’t as waterproof as they said.
Sorry I cannot answer at short notice. When I work I work and this I do on my spare time when I get some time over.
The i2c is one way communicate digital over 2 wires. You actually don’t need to know exactly how it works if you not going to do your own library.
Usually called the pins sda and scl. They also have an address that define where to get the data. Because you can have several devices on a i2c bus as long as the dont have the same address.
Another way communicating is using spi. It uses more wires 3 or 4.
But it also a way to communicate digital with sensor and other things.
But it sending the data digital as bytes. When it works it works and when it doesn’t it’s usually is hard too know why it’s not.
There is actually very good information on the esphome.
If you want to understand. I suggest to start with an arduino uno and connect sensor to that and use library for the sensors. There are tons of tutorials and resources on internet just a google away.
To give you more background how everything works. maybe that is a way.
I will look at this thanks, i am realising thet the learning curve is quite steep for someone who had never programmed anything his entire life, I had a basic knowledge of html and css but that was it, now i’ve learned quite a few new things in different languages, I started by learning how to use a terminal on my mac then on a raspberry pi2 then 3 then 4… then i started using microcontrollers since about a year now, so this is all still new to me, it’s hard but I want to learn this, especially that i am currently using this as a template for my real grow operation in which I wish to implement it at a later point. so that my old mom doesn’t have to go to the greenhouses so often and have more control over the whole thing.
I am having fun, but sometimes i get to roadblocks like now… i cant figure things by myself… that’s why im here
anyways thanks a bunch, the thing is that the humidity part seems to work okay not perfect but at least not stuck at a single temperature all day. when it’s outside of the ground… ill re, dry and re-wire it, and ill see what’s up.
and it is’nt well documented for this specific sensor, at all… it is for the sht31, but not really much for the sht30 sensor …
