configuration is valid:
INFO Configuration is valid!
esphome:
platform: ESP32
board: nodemcu-32s
arduino_version: platformio/[email protected]
build_path: esp32test
platformio_options: {}
includes: []
libraries: []
name_add_mac_suffix: false
wifi:
ap:
ssid: Test Fallback Hotspot
password:XXXXXXXXXXXX
ap_timeout: 1min
enable_mdns: true
domain: .local
Here is the log:
this is the latest version from 2 minutes ago with sensor hooked on the esp32 and from the UI
INFO Reading configuration /config/esphome/test.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running: platformio run -d /config/esphome/esp32test
Processing esp32test (board: nodemcu-32s; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif32 3.10004.210126 (1.0.4)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Library Manager: Installing Hash
Library Manager: Already installed, built-in library
Dependency Graph
|-- <AsyncTCP-esphome> 1.2.2
|-- <FS> 1.0
|-- <ESPAsyncWebServer-esphome> 1.2.7
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <Wire> 1.0.1
|-- <DNSServer> 1.1.0
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/api_connection.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/api_server.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/list_entities.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/proto.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/user_services.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/api/util.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/i2c/i2c.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/logger/logger.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/sensor/automation.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/sensor/filter.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/sensor/sensor.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/sht3xd/sht3xd.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/wifi/wifi_component_esp32.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/application.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/component.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/controller.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/esphal.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/helpers.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/log.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/preferences.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/scheduler.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/esphome/core/util.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/src/main.cpp.o
Generating partitions /data/esp32test/.pioenvs/esp32test/partitions.bin
Compiling /data/esp32test/.pioenvs/esp32test/lib150/AsyncTCP-esphome/AsyncTCP.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/lib150/libAsyncTCP-esphome.a
Compiling /data/esp32test/.pioenvs/esp32test/lib790/FS/FS.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib790/FS/vfs_api.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/lib790/libFS.a
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/ETH.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFi.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiAP.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiClient.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiGeneric.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiMulti.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiSTA.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiScan.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiServer.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib789/WiFi/WiFiUdp.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/lib789/libWiFi.a
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/SPIFFSEditor.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/lib768/ESPAsyncWebServer-esphome/WebServer.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/lib768/libESPAsyncWebServer-esphome.a
Compiling /data/esp32test/.pioenvs/esp32test/libe94/ESPmDNS/ESPmDNS.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/libe94/libESPmDNS.a
Compiling /data/esp32test/.pioenvs/esp32test/lib767/Wire/Wire.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/lib767/libWire.a
Compiling /data/esp32test/.pioenvs/esp32test/lib43b/DNSServer/DNSServer.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/lib43b/libDNSServer.a
Compiling /data/esp32test/.pioenvs/esp32test/liba61/Update/Updater.cpp.o
Archiving /data/esp32test/.pioenvs/esp32test/liba61/libUpdate.a
Archiving /data/esp32test/.pioenvs/esp32test/libFrameworkArduinoVariant.a
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/Esp.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/HardwareSerial.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/IPAddress.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/IPv6Address.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/MD5Builder.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/Print.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/Stream.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/StreamString.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/WMath.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/WString.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/base64.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/cbuf.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-adc.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-bt.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-cpu.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-dac.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-gpio.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-i2c.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-ledc.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-matrix.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-misc.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-psram.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-rmt.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-spi.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-time.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-timer.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-touch.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/esp32-hal-uart.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/libb64/cdecode.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/libb64/cencode.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/main.cpp.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/stdlib_noniso.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/wiring_pulse.c.o
Compiling /data/esp32test/.pioenvs/esp32test/FrameworkArduino/wiring_shift.c.o
Archiving /data/esp32test/.pioenvs/esp32test/libFrameworkArduino.a
Linking /data/esp32test/.pioenvs/esp32test/firmware.elf
Building /data/esp32test/.pioenvs/esp32test/firmware.bin
Retrieving maximum program size /data/esp32test/.pioenvs/esp32test/firmware.elf
Checking size /data/esp32test/.pioenvs/esp32test/firmware.elf
RAM: [= ] 13.2% (used 43104 bytes from 327680 bytes)
Flash: [===== ] 48.8% (used 894714 bytes from 1835008 bytes)
======================== [SUCCESS] Took 224.92 seconds ========================
INFO Successfully compiled program.
INFO Running: platformio run -d /config/esphome/esp32test -t upload --upload-port /dev/ttyUSB0
PACKAGES:
- tool-mkspiffs 2.230.0 (2.30)
Dependency Graph
|-- <FS> 1.0
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <Wire> 1.0.1
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Configuring upload protocol...
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Use manually specified: /dev/ttyUSB0
Uploading /data/esp32test/.pioenvs/esp32test/firmware.bin
Serial port /dev/ttyUSB0
Connecting........_
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 9c:9c:1f:c7:89:58
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
A fatal error occurred: Timed out waiting for packet header
*** [upload] Error 2
========================= [FAILED] Took 13.58 seconds =========================
Still the same error I had yesterday all day.
It uploads when the sensor is NOT hooked on the board but as soon as i hook the sensor on it it doesnt boot anymore.
Here is the result when sensor NOT hooked on the esp wroom 32 while uploading:
PACKAGES:
Dependency Graph
|-- <FS> 1.0
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <Wire> 1.0.1
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
========================= [SUCCESS] Took 6.73 seconds =========================
PACKAGES:
Dependency Graph
|-- <FS> 1.0
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <Wire> 1.0.1
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Connecting........_
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Auto-detected Flash size: 4MB
Compressed 15872 bytes to 10319...
Writing at 0x00001000... (100 %)
Wrote 15872 bytes (10319 compressed) at 0x00001000 in 0.9 seconds (effective 136.5 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 144...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.0 seconds (effective 969.8 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4045.3 kbit/s)...
Compressed 894832 bytes to 498843...
Writing at 0x00010000... (3 %)
Writing at 0x00014000... (6 %)
Writing at 0x00018000... (9 %)
Writing at 0x0001c000... (12 %)
Writing at 0x00020000... (16 %)
Writing at 0x00024000... (19 %)
Writing at 0x00028000... (22 %)
Writing at 0x0002c000... (25 %)
Writing at 0x00030000... (29 %)
Writing at 0x00034000... (32 %)
Writing at 0x00038000... (35 %)
Writing at 0x0003c000... (38 %)
Writing at 0x00040000... (41 %)
Writing at 0x00044000... (45 %)
Writing at 0x00048000... (48 %)
Writing at 0x0004c000... (51 %)
Writing at 0x00050000... (54 %)
Writing at 0x00054000... (58 %)
Writing at 0x00058000... (61 %)
Writing at 0x0005c000... (64 %)
Writing at 0x00060000... (67 %)
Writing at 0x00064000... (70 %)
Writing at 0x00068000... (74 %)
Writing at 0x0006c000... (77 %)
Writing at 0x00070000... (80 %)
Writing at 0x00074000... (83 %)
Writing at 0x00078000... (87 %)
Writing at 0x0007c000... (90 %)
Writing at 0x00080000... (93 %)
Writing at 0x00084000... (96 %)
Writing at 0x00088000... (100 %)
Wrote 894832 bytes (498843 compressed) at 0x00010000 in 44.5 seconds (effective 160.7 kbit/s)...
Leaving...
Hard resetting via RTS pin...
========================= [SUCCESS] Took 56.98 seconds =========================
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[19:05:51][I][logger:170]: Log initialized
[19:05:51][C][ota:366]: There have been 1 suspected unsuccessful boot attempts.
[19:05:51][I][app:029]: Running through setup()...
[19:05:51][C][sht3xd:019]: Setting up SHT3xD...
[19:05:51][W][i2c:070]: Received NACK on transmit of address 0x44
[19:05:51][E][component:092]: Component was marked as failed.
[19:05:51][C][wifi:033]: Setting up WiFi...
[19:05:51][D][wifi:324]: Starting scan...
[19:05:52][D][wifi:339]: Found networks:
[19:05:52][I][wifi:385]: - 'Netgear_dd' [redacted]▂▄▆█
[19:05:52][D][wifi:386]: Channel: 6
[19:05:52][D][wifi:387]: RSSI: -42 dB
[19:05:52][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[19:05:53][D][wifi:389]: - [redacted] [redacted]▂▄▆█
[19:05:53][I][wifi:194]: WiFi Connecting to 'Netgear_dd'...
[19:05:54][I][wifi:457]: WiFi Connected!
[19:05:54][C][wifi:303]: SSID: [redacted]
[19:05:54][C][wifi:304]: IP Address: 192.168.1.127
[19:05:54][C][wifi:306]: BSSID: [redacted]
[19:05:54][C][wifi:307]: Hostname: 'esp32test'
[19:05:54][C][wifi:311]: Signal strength: -39 dB@▂▄▆█
[19:05:54][C][wifi:315]: Channel: 6
[19:05:54][C][wifi:316]: Subnet: 255.255.255.0
[19:05:54][C][wifi:317]: Gateway: 192.168.1.1
[19:05:54][C][wifi:318]: DNS1: 192.168.1.1
[19:05:54][C][wifi:319]: DNS2: 0.0.0.0
[19:05:54][D][wifi:466]: Disabling AP...
[19:05:54][C][ota:029]: Over-The-Air Updates:
[19:05:54][C][ota:030]: Address: esp32test.local:3232
[19:05:54][C][ota:032]: Using Password.
[19:05:54][C][api:022]: Setting up Home Assistant API server...
[19:05:54][I][app:059]: setup() finished successfully!
[19:05:54][I][app:105]: ESPHome version 1.18.0 compiled on May 22 2021, 18:56:50
[19:05:54][C][wifi:443]: WiFi:
[19:05:54][C][wifi:311]: Signal strength: -40 dB ▂▄▆█
[19:05:54][C][i2c:028]: I2C Bus:
[19:05:54][C][i2c:029]: SDA Pin: GPIO21
[19:05:54][C][i2c:030]: SCL Pin: GPIO22
[19:05:54][C][i2c:031]: Frequency: 50000 Hz
[19:05:54][C][logger:189]: Logger:
[19:05:54][C][logger:190]: Level: DEBUG
[19:05:54][C][logger:191]: Log Baud Rate: 115200
[19:05:54][C][logger:192]: Hardware UART: UART0
[19:05:54][C][sht3xd:034]: SHT3xD:
[19:05:54][C][sht3xd:035]: Address: 0x44
[19:05:54][E][sht3xd:037]: Communication with SHT3xD failed!
[19:05:54][C][sht3xd:039]: Update Interval: 60.0s
[19:05:54][C][sht3xd:041]: Temperature 'zone1 soil Temperature'
[19:05:54][C][sht3xd:041]: Device Class: 'temperature'
[19:05:54][C][sht3xd:041]: Unit of Measurement: '°C'
[19:05:54][C][sht3xd:041]: Accuracy Decimals: 1
[19:05:54][C][sht3xd:042]: Humidity 'zone1 soil Humidity'
[19:05:54][C][sht3xd:042]: Device Class: 'humidity'
[19:05:54][C][sht3xd:042]: Unit of Measurement: '%'
[19:05:54][C][sht3xd:042]: Accuracy Decimals: 1
[19:05:54][C][captive_portal:169]: Captive Portal:
[19:05:54][C][api:095]: API Server:
[19:05:54][C][api:096]: Address: esp32test.local:6053
So i think its the code that is wrong, maybe the wrong type of sensor? I don’t know I’m kinda out of ideas now…
