Hi everyone!
Looking for community’s help. Have thermostatic radiator valve ( Moes BRT-100-TRV ), it has been installed on radiator that closed by decorative panels (it’s mean that around battery always hot but temperature in the room is lower). My task is to manage thermostat not using it internal temperature sensor ( coz it always shows high temperature) but based on external temperature sensor.
Have you actually investigated before buying, if the valve inside the thermostat is capable of being operated directly?
Not every Thermostat valve is able to do that. If it can be directly operated, you will find something about it in the manual.
