Help with ThirdReality zigbee button
I just picked up one of these to test with. I have a couple of the old round Aqara buttons, but they are really hard to find and I like the idea of a larger capacity battery.
I have the following automation that works great with an NFC tag, but the wife and kids do not like to scan the tag and then complain. So, my plan is to add the switch or replace the tag altogether with the switch.
The problem… the button registers with 2 zha events as follows, it appears in the log book twice as well…
I have tried command: on , “on”, single and “single” but the automation never triggers on the button.
What am I doing wrong?
event_type: zha_event
  device_ieee: 28:2c:02:bf:ff:e3:8a:00
  unique_id: 28:2c:02:bf:ff:e3:8a:00:1:0x0012
  device_id: 18c287afedeebcc470917484edfc1408
  endpoint_id: 1
  cluster_id: 18
  command: single
  args:
    value: 1
  params: {}
origin: LOCAL
time_fired: "2023-11-29T04:07:32.982899+00:00"
context:
  parent_id: null
  user_id: null
  unique_id: 28:2c:02:bf:ff:e3:8a:00:1:0x0006
  endpoint_id: 1
  cluster_id: 6
  command: "on"
  args: []
  params: {}
origin: LOCAL
time_fired: "2023-11-29T04:07:32.973656+00:00"
context:
  parent_id: null
  user_id: null
- id: nfc_bathroom_heat
  alias: NFC bathroom heat
  mode: restart
  trace:
    stored_traces: 10
    - platform: tag
      tag_id: 5c75bdd6-20d2-4d08-a28b-a3944363782c
    - platform: event
      event_data:
        command: "single"
    - choose:
        - conditions:
            - condition: state
              entity_id: switch.bathroom_heater
              state: 'off'
            - condition: time
              after: '06:00:00'
              before: '23:00:00'
          sequence:
            - service: switch.turn_on
            - service: light.turn_on
              entity_id: light.bathroom_1,light.bathroom_2
                brightness_pct: 100
                kelvin: 5000
            - service: timer.start
              entity_id: timer.bathroom_heat_tag
                entity_id: input_boolean.notify_bathroom_tag
            - service: timer.cancel
              entity_id: timer.bathroom_motion_long
              entity_id: timer.bathroom_motion_short
            - service: system_log.write
                message: NFC Tag Bathroom scanned to turn on heat
#              logger: automation Bathroom NFC tag scanned
### Late night tag scan test.
        - conditions:
            - condition: state
              state: 'off'
            - condition: time
              after: '23:00:00'
              before: '06:00:00'
          sequence:
              entity_id: light.bathroom_1,light.bathroom_2,light.sink,light.tree_top,light.lamp1
                brightness_pct: 100
                kelvin: 4000
#                transition: 120
                message: NFC Tag Bathroom scanned to turn on heat during late night
        - conditions:
            - condition: state
              state: 'on'
          sequence:
#            - service: timer.finish
#              entity_id: timer.bathroom_heat_tag
            - service: switch.turn_off
            - service: input_boolean.turn_off
                message: NFC Tag Bathroom scanned to turn off heat
I just set one of these up yesterday using switch.turn_on. Does it work from the developer tools calling the service?
I am not sure what made the difference… but the following works today. I wonder if the reload automations in the file editor was not really reloading like it should have… I reloaded automations from developers tools and it now works.
This is what worked for me.
  mode: restart
  trace:
    stored_traces: 10
    - platform: tag
    - platform: event
      event_data:
        command: "on"
