Pas940
(Paul Shaw)
June 7, 2020, 5:21am
1
This is gettig the better of me, I want it to be fast, like microcontroler fast. I had it working but still had issues with is only running when the sensor updated. I’m trying to implement a crude solar constant voltage input control as an approx to MPP. it doesn’t matter if I get voltage overshoot or undershoot but id like it to be faster than the sensor update.
I think i need the an analog read in a lamda that runs all the time?
logic is simple, if voltage is above 100v increase pwm duty, if it’s below 80v reduce it.
This is where im at with it atm it’s getting messy as im fiddling with it and getting tired.
globals:
- id: pwm_int
type: float
restore_value: no
initial_value: '0'
- id: pwm_test
type: int
restore_value: no
initial_value: '0'
esphome:
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: "ssid"
password: "pswd"
ap:
ssid: "Hotwater Fallback Hotspot"
password: "ybeV8oeqSVkM"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
output:
- platform: ledc
pin: GPIO19
frequency: 19500
- platform: adc
pin: GPIO34
filters:
- multiply: 100
update_interval: 3s
lambda: !lambda |-
if (id(voltage)>100) {
id(pwm_int) += 0.1;
-output.set_level:
level: !lambda 'return id(pwm_int);'
if (id(voltage)<80) {
id(pwm_int) -= 0.1;
-output.set_level:
level: 50% #!lambda 'return id(pwm_int);'
# on_value_range:
# - above: 100.0
# then:
# - lambda: 'id(pwm_int) += 0.1;'
# - output.set_level:
# id: gpio_19
# level: !lambda 'return id(pwm_int);'
# - below: 80.0
# then:
# - lambda: 'id(pwm_int) -= 0.1;'
# id: gpio_19
# update_interval: 2s
#light:
# - platform: monochromatic
# output: gpio_19
# name: "hotwater pwm"
nickrout
(Nick Rout)
June 7, 2020, 5:26am
2
Pas940:
MPP
Ministry for Pacific Peoples is returned in google.
How about you tell us what is going wrong - we can’t guess. What result are you seeing/not seeing?
Pas940
(Paul Shaw)
June 7, 2020, 5:45am
3
I ran out of talent thats whats wrong.
MPP stands for max power point, doesn’t matter. above 100 duty up, below 80 duty down, as fast as it can.
Like I said I want it to run fast like arduino code, not only in the update interval like the comented out version did.
Pas940
(Paul Shaw)
June 7, 2020, 7:04am
4
I’ve tidied it up, now all it does on the first time it goes over the 100 it sets it to 10% duty but even if the voltage remains above 100 it doesn’t do it again, and even if it did I think it’d only do it at the update interval, what happens if i set my update interval too short ? flood wifi/ database?? seems the wront way to do it.
globals:
- id: pwm_int
type: float
restore_value: no
initial_value: '0'
- id: pwm_test
type: int
restore_value: no
initial_value: '0'
esphome:
platform: ESP32
wifi:
ssid: "
password: ""
ap:
captive_portal:
logger:
api:
ota:
output:
- platform: ledc
pin: GPIO19
frequency: 19500
- platform: adc
pin: GPIO34
filters:
- multiply: 100
update_interval: 3s
on_value_range:
- above: 100.0
then:
- output.set_level:
- below: 80.0
then:
- output.set_level:
Pas940
(Paul Shaw)
June 7, 2020, 7:19am
5
more i think about it the code needs to do it all in a lambda, I know the adc counts won’t be in the same units but I can work that out.
if (analogRead(Pin34)>100))
pwm +=0.1;
if (analogRead(Pin34)<80))
pwm -=0.1;
ledcAttachPin(GPIO 19, 1);
ledcWrite(1,pwm)
Pas940
(Paul Shaw)
June 7, 2020, 8:01am
6
This gives an error “component not found: lambda”
I’m guessing I can’t use a lambda that just runs all the time it has to be inside a sensor or some othe block of yaml??
Maybe i need to read the custom sensor component?
- id: pwm_float
type: float
restore_value: no
initial_value: '0'
- id: pwm_test
type: int
restore_value: no
initial_value: '0'
esphome:
platform: ESP32
wifi:
ssid: ""
password:
ap:
captive_portal:
logger:
api:
ota:
output:
- platform: ledc
pin: GPIO19
frequency: 19500
channel: 0
- platform: adc
pin: GPIO34
filters:
- multiply: 100
update_interval: 3s
#!lambda |-
lambda: !lambda |-
if (analogRead(Pin34)>100)) {
pwm_float +=0.1;
if (analogRead(Pin34)<80)) {
pwm_float -=0.1;
ledcWrite(0,pwm_float);
