Hello to everyone could someone help me with this template sensor:
#Energia Immessa in WATT
energia_immessa_w_attuale:
value_template: >
{% if states('sensor.fotovoltaico_solar_current_power') | float > states('sensor.shellyem_f4cfa2e45ce7_channel_1_power') | float -%}
{{ states('sensor.fotovoltaico_solar_current_power') | float - states('sensor.shellyem_f4cfa2e45ce7_channel_1_power') | float }}
{%- else -%}
0
{%- endif %}
unit_of_measurement: W
device_class: energy
friendly_name: Energia Immessa W Attuale
I have this error sometimes when the solar panel goes offline:
Template warning: 'float' got invalid input 'unavailable' when rendering template '{% if states('sensor.fotovoltaico_solar_current_power') | float > states('sensor.shellyem_f4cfa2e45ce7_channel_1_power') | float -%} {{ states('sensor.fotovoltaico_solar_current_power') | float - states('sensor.shellyem_f4cfa2e45ce7_channel_1_power') | float }} {%- else -%} 0 {%- endif %}' but no default was specified. Currently 'float' will return '0', however this template will fail to render in Home Assistant core 2021.12
Could i put some if or something else?
I have used this template for calculate the power that i put to the grid.
Thanks a lot
Stefano
Hi, just update HA to 2021.10.6.
I have several “float” in my configuration.yaml.
Can I use the replace command to replace them all with float(0) ?
Using the float(0) filter will avoid the warning you saw, but it isn’t necessarily always the right thing to do. Think, for example, whether you have any automation that triggers off of this sensor, and whether or not the automation would trigger if that float value is zero.
Another approach is to use is_number() in your value template. For example, I have one like this:
