I have an automation to turn on a group of radiator trv’s. I tested the automation initially with a time trigger and it worked as expected.
However, I then created an input boolean toggle in the UI and wanted to use that to trigger the automation instead. I amended only the trigger but it now won’t run.
The only entry in the log each time it fails is a Spook error which doesn’t specifically name either the automation or script but it appears each time I try to trigger the automation using the toggle.
Can anyone please help with what I’m not seeing.
Script:
home_heating_on:
alias: Home Heating ON
sequence:
- service: climate.set_temperature
entity_id: group.thermostats
temperature: 19
mode: single
Automation:
- alias: Heating All Rooms ON
mode: single
- platform: state
entity: input_boolean.home_heating
to: 'on'
condition:
- condition: state
entity_id: input_boolean.holiday_mode
state: 'off'
- service: script.turn_on
entity_id: script.home_heating_on
Spook Error:
This error originated from a custom integration.
Logger: custom_components.spook
Source: helpers/debounce.py:114
Integration: Spook (documentation, issues)
First occurred: 8:38:42 AM (227 occurrences)
Last logged: 11:09:33 AM
Unexpected exception from <function AbstractSpookRepair.async_activate.<locals>._async_inspect at 0x7f59599e7a60>
File "/usr/src/homeassistant/homeassistant/helpers/debounce.py", line 114, in _handle_timer_finish
await task
File "/config/custom_components/spook/repairs.py", line 130, in _async_inspect
await self.async_inspect()
File "/config/custom_components/spook/ectoplasms/script/repairs/unknown_entity_references.py", line 99, in async_inspect
for entity_id in entity.script.referenced_entities
AttributeError: 'UnavailableScriptEntity' object has no attribute 'script'
