No, it won’t, areks solution only check if the state is true 3 minutes after every state change to true, without noticing how many times it changed in between. A better solution for your problem would be to use the trigger node, configured like this it will only emit states stable for at least 3 minutes and discard every state which is not. Then a simple switch node to check if the state (which have been stable for 3 minutes) is actually true.
Note that you have to check the “Output only on state change” checkbox on the events:state node.
[{“id”:“845a6ca0.379698”,“type”:“trigger”,“z”:“eeb7694d.de6c18”,“op1”:“”,“op2”:“”,“op1type”:“nul”,“op2type”:“payl”,“duration”:“3”,“extend”:true,“units”:“min”,“reset”:“”,“bytopic”:“all”,“name”:“”,“x”:517,“y”:1423,“wires”:[[“99b37f7.c8cfd”]]},{“id”:“8c3c94c8.90138”,“type”:“server-state-changed”,“z”:“eeb7694d.de6c18”,“name”:“”,“server”:“b3647e80.a78bd”,“entityidfilter”:“input_boolean.notalone”,“entityidfiltertype”:“exact”,“outputinitially”:false,“state_type”:“habool”,“haltifstate”:“”,“halt_if_type”:“str”,“halt_if_compare”:“is”,“outputs”:1,“output_only_on_state_change”:true,“x”:276,“y”:1423,“wires”:[[“845a6ca0.379698”]]},{“id”:“99b37f7.c8cfd”,“type”:“switch”,“z”:“eeb7694d.de6c18”,“name”:“true?”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“true”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:656.5,“y”:1423,“wires”:[]},{“id”:“b3647e80.a78bd”,“type”:“server”,“z”:“”,“name”:“HASS”,“legacy”:false,“hassio”:false,“rejectUnauthorizedCerts”:true,“ha_boolean”:“y|yes|true|on|home|open”}]
