I’ve recently moved over to Home Assistant and am quite impressed with it. Unfortunately my home automation gear is rather piece meal, as each item was bought to solve an issue, rather than part of a cohesive plan. That said, most things are working quite well, but I’m struggling with three items and was hoping for some assistance (either in crafting our troubleshooting the automation). As a likely relevant point, I have HomeAssistant install on a separate VLAN than my devices.
The first is that I’d like a series of events to fire when my Reading Light is turned off (it’s plugged into a Lutron Lamp Dimmer). When ran manually everything works, but it doesn’t seem to pick up the state of the lamp and therefore doesn’t fire when it’s needed.
The second is I’m struggling for Home Assistant to pick up the state (“eco”) of my Nest thermostat and fire actions based on that. Again, works fine manually, but doesn’t auto pick it up.
The last thing is I’m using the default weather app / plugin, and would like to leverage it to turn on my outside lights when the weather changes to rainy/snowy, and turn off the lights again when it turns sunny or clear. Any thoughts on how to do this?
Thanks in advance for any help / guidance that you can provide. I’m looking forward to going down the rabbit hole that HA provides
I suspect your triggers are wrong on the first two. Double check using the the Developers Tools that the value you are looking for on the lamp when off for example is at the value you are testing for. Running the automation manually ignores the triggers.
For the weather ones, the simple way is to use a trigger on the weather changes and then use a Choose to set the action for each set of weather.
If you are still struggling it would help if you can post what you are currently doing and the values from the developer tools
Thank you for all your help, it’s really appreciated. Your suggestions resolved one of the issues.
It appears that the issue lies with the Nest API not correctly reporting that it is in eco mode when it’s triggered by being “away”. In fact, nothing updates in HA when the Nest Thermostat is in away mode (not the temp setting, etc). So to utilize the HA presence sensing, I’ll need to wait for further updates I suppose. This leads to my question of what do people use for presence sensing besides their cell phones?
Finally, for the weather, is it possible to see what variables it supports (sunny, rainy, etc)?
