zha-6key.log
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x6762), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.Broadcast: 15>, address=<BroadcastAddress.RX_ON_WHEN_IDLE: 65533>), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=19, data=Serialized[b'\x03bg6\x1fed\xa38\xc1\xa4\x8e'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-54)
New device 0x6762 (a4:c1:38:a3:64:65:1f:36) joined the network
[0x6762] Scheduling initialization
Received frame on uninitialized device <Device model=None manuf=None nwk=0x6762 ieee=a4:c1:38:a3:64:65:1f:36 is_initialized=False> from ep 0 to ep 0, cluster 19: b'\x03bg6\x1fed\xa38\xc1\xa4\x8e'
[0x6762:zdo] ZDO request ZDOCmd.Device_annce: [0x6762, a4:c1:38:a3:64:65:1f:36, 142]
Tries remaining: 3
[0x6762] Requesting 'Node Descriptor'
Tries remaining: 2
[0x6762] Extending timeout for 0xbd request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x6762), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=None, profile_id=0, cluster_id=32770, data=Serialized[b'\xbd\x00bg\x01@\x8eA\x11BB\x00\x00*B\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-55)
This file has been truncated. show original
