Help with turn leds on with nod-red
Hello guys,
Im trying to do something, i want to turn on the leds at the morning 7am, and turn on white, but this example only turn on the leds and dont change the color:
Notes: i know one is disable and the color is blue, is my example but isnt working so i disable and fix it with a goolge rutine, but i want to do it this way, this example just turn on the leds, but dont change the color.
Screenshot_3
Try setting JSON instead of experssion in your data frield.
Thanks for the answer, i have the same result :frowning:
the light may not support rgb_color try {"color_name":"blue"}
stay on turning the light but dont change the color :frowning:
Cant find a solution yet, Thanks for the help if you post after or before this :slight_smile:
