hb9ezs
(Patrick)
January 23, 2025, 8:49am
21
I just tried the 3.3V TX on the WL-134 RFID reader, but this neither worked with the ESP32, nor with the Arduino.
I also tried a voltage divider with a 1kΩ and a 2kΩ resistor in combination with the 5V TX, but this didn’t work either.
I’m really out of ideas…
Karosm
(Karosm)
January 23, 2025, 11:14am
22
Let’s take some odds out. Connect Gpio4 to Gpio5 with jumper wire.
logger:
baud_rate: 0
uart:
tx_pin: GPIO4
rx_pin: GPIO5
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
interval:
- interval: 10s
then:
- uart.write: "Hello World\r\n"
If you don’t get anything received, I don’t know what to think next…
hb9ezs
(Patrick)
January 23, 2025, 11:32am
23
Great idea, this works!
This is the first time I see something on the UART RX of the ESP32
hb9ezs
(Patrick)
January 23, 2025, 12:02pm
25
Forget my last reply, I was wrong. In the logs I only see that the ESP32 posted something to TX.
[12:58:24][D][uart_debug:158]: >>> "Hello World\r\n"
[12:58:34][D][uart_debug:158]: >>> "Hello World\r\n"
[12:58:44][D][uart_debug:158]: >>> "Hello World\r\n"
[12:58:54][D][uart_debug:158]: >>> "Hello World\r\n"
[12:59:04][D][uart_debug:158]: >>> "Hello World\r\n"
[12:59:14][D][uart_debug:158]: >>> "Hello World\r\n"
[12:59:24][D][uart_debug:158]: >>> "Hello World\r\n"
[12:59:34][D][uart_debug:158]: >>> "Hello World\r\n"
[12:59:44][D][uart_debug:158]: >>> "Hello World\r\n"
Karosm
(Karosm)
January 23, 2025, 12:56pm
26
Remove the line
baud_rate: 0
Esphome should configure second UART on your pins.
Post the log when compiling.
hb9ezs
(Patrick)
January 23, 2025, 1:16pm
27
Here are my logs:
Logs
INFO ESPHome 2024.12.2
INFO Reading configuration /config/esphome/catdoor.yaml...
WARNING The selected ESP-IDF framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
INFO Compiling app...
Processing catdoor (board: esp32-c6-devkitc-1; framework: espidf; platform: platformio/[email protected] )
HARDWARE: ESP32C6 160MHz, 320KB RAM, 8MB Flash
- framework-espidf @ 3.50301.0 (5.3.1)
- tool-cmake @ 3.16.9
- tool-ninja @ 1.10.2
- tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
- tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-riscv32-esp @ 13.2.0+20240530
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.6
Compiling .pioenvs/catdoor/src/main.cpp.o
Linking .pioenvs/catdoor/firmware.elf
RAM: [= ] 11.5% (used 37596 bytes from 327680 bytes)
Flash: [=== ] 26.3% (used 1033557 bytes from 3932160 bytes)
Building .pioenvs/catdoor/firmware.bin
Creating esp32c6 image...
Successfully created esp32c6 image.
esp32_create_combined_bin([".pioenvs/catdoor/firmware.bin"], [".pioenvs/catdoor/firmware.elf"])
Wrote 0x10c6c0 bytes to file /data/build/catdoor/.pioenvs/catdoor/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([".pioenvs/catdoor/firmware.bin"], [".pioenvs/catdoor/firmware.elf"])
========================= [SUCCESS] Took 29.94 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.1.164 port 3232...
INFO Connected to 192.168.1.164
INFO Uploading /data/build/catdoor/.pioenvs/catdoor/firmware.bin (1033920 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 3.23 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.164 using esphome API
INFO Successfully connected to catdoor @ 192.168.1.164 in 4.098s
INFO Successful handshake with catdoor @ 192.168.1.164 in 0.084s
[13:57:46][I][app:100]: ESPHome version 2024.12.2 compiled on Jan 23 2025, 13:57:17
[13:57:46][C][wifi:600]: WiFi:
[13:57:46][C][wifi:428]: Local MAC: ********
[13:57:46][C][wifi:433]: SSID: [redacted]
[13:57:46][C][wifi:436]: IP Address: 192.168.1.164
[13:57:46][C][wifi:439]: BSSID: [redacted]
[13:57:46][C][wifi:441]: Hostname: 'catdoor'
[13:57:46][C][wifi:443]: Signal strength: -58 dB ▂▄▆█
[13:57:46][C][wifi:447]: Channel: 6
[13:57:46][C][wifi:448]: Subnet: 255.255.255.0
[13:57:46][C][wifi:449]: Gateway: 192.168.1.1
[13:57:46][C][wifi:450]: DNS1: 0.0.0.0
[13:57:46][C][wifi:451]: DNS2: 0.0.0.0
[13:57:46][C][logger:185]: Logger:
[13:57:46][C][logger:186]: Level: DEBUG
[13:57:46][C][logger:188]: Log Baud Rate: 115200
[13:57:46][C][logger:189]: Hardware UART: UART0
[13:57:46][C][uart.idf:159]: UART Bus 1:
[13:57:46][C][uart.idf:160]: TX Pin: GPIO4
[13:57:46][C][uart.idf:161]: RX Pin: GPIO5
[13:57:46][C][uart.idf:163]: RX Buffer Size: 256
[13:57:46][C][uart.idf:165]: Baud Rate: 9600 baud
[13:57:46][C][uart.idf:166]: Data Bits: 8
[13:57:46][C][uart.idf:167]: Parity: NONE
[13:57:46][C][uart.idf:168]: Stop bits: 1
[13:57:46][C][captive_portal:089]: Captive Portal:
[13:57:46][C][mdns:116]: mDNS:
[13:57:46][C][mdns:117]: Hostname: catdoor
[13:57:46][C][esphome.ota:073]: Over-The-Air updates:
[13:57:46][C][esphome.ota:074]: Address: 192.168.1.164:3232
[13:57:46][C][esphome.ota:075]: Version: 2
[13:57:46][C][esphome.ota:078]: Password configured
[13:57:46][C][safe_mode:018]: Safe Mode:
[13:57:46][C][safe_mode:019]: Boot considered successful after 60 seconds
[13:57:46][C][safe_mode:021]: Invoke after 10 boot attempts
[13:57:46][C][safe_mode:022]: Remain in safe mode for 300 seconds
[13:57:46][C][api:140]: API Server:
[13:57:46][C][api:141]: Address: 192.168.1.164:6053
[13:57:46][C][api:143]: Using noise encryption: YES
[13:57:47][D][api:103]: Accepted 192.168.1.126
[13:57:47][D][api.connection:1446]: Home Assistant 2025.1.2 (192.168.1.126): Connected successfully
[13:57:51][D][uart_debug:158]: >>> "Hello World\r\n"
[13:58:01][D][uart_debug:158]: >>> "Hello World\r\n"
[13:58:11][D][uart_debug:158]: >>> "Hello World\r\n"
[13:58:21][D][uart_debug:158]: >>> "Hello World\r\n"
[13:58:31][D][uart_debug:158]: >>> "Hello World\r\n"
[13:58:41][D][uart_debug:158]: >>> "Hello World\r\n"
And here is my current config:
Config
esphome:
friendly_name: Cat Door
esp32:
flash_size: 8MB
variant: esp32c6
framework:
type: esp-idf
version: 5.3.1
platform_version: 6.9.0
uart:
tx_pin: GPIO4
rx_pin: GPIO5
baud_rate: 9600
debug:
direction: BOTH
after:
delimiter: "\n"
sequence:
interval:
- interval: 10s
then:
logger:
api:
encryption:
key: "***"
ota:
- platform: esphome
password: "***"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.164
gateway: 192.168.1.1
subnet: 255.255.255.0
power_save_mode: none
ap:
ssid: "***"
password: "***"
captive_portal:
Karosm
(Karosm)
January 23, 2025, 1:49pm
28
Ok, now pins 4/5 are set on UART1 and your code looks generally ok.
But I’m not sure where uart.write is writing, UART0 or UART1.
add id to your uart component:
and replace the interval component with this:
interval:
- interval: 10s
then:
- uart.write:
data: "Hello World\r\n"
hb9ezs
(Patrick)
January 23, 2025, 2:04pm
29
I have tried this, but got the same result.
Also, I have removed the version definition in my config due to the warning in the logs, but this also didn’t help.
Karosm
(Karosm)
January 23, 2025, 2:14pm
30
Ok, we have tested on both uarts, different pins etc.
My tool pack is empty.
I think that uart debug simply doesn’t work for C6 on this software version.
Or all your jumper wires are broken…
hb9ezs
(Patrick)
January 23, 2025, 3:20pm
32
In this post, the ESP32-C6-DevKitC-1 worked with UART, so I think it should be possible:
Hello everyone,
I’m using an ESP32-C6 board connected to two A02YYUW ultrasonic distance sensors. When I enable both sensors, my device reboots continuously and I get an error in the logs:
[W][uart.idf:088]: Maximum number of UART components created already. [E][component:119]: Component uart was marked as failed. [E][component:164]: Component uart set Error flag: unspecified ... assert failed: xQueueSemaphoreTake queue.c:1653 (( pxQueue )) Core 0 register dump: ... Rebooting...
My YAML Conf…
@matteor how do your logs looks like? Can you see the UART RX?
Karosm
(Karosm)
January 23, 2025, 4:31pm
33
It’s slightly different because there is a real device/component.
Yours relies on debug option dummy_receiver.
hb9ezs
(Patrick)
January 23, 2025, 8:34pm
34
Wow, it worked!!
I have disabled the debugger and used the WL-134 text component:
[21:23:40][D][text_sensor:064]: 'Transponder Code': Sending state '900158002020048'
[21:23:41][D][uart_debug:114]: <<< 00:02:30:44:45:37:37:41:39:43:34:32:34:38:33:30:31:31:30:30:30:30:30:30:30:30:30:30:03:FC:03
[21:23:42][D][text_sensor:064]: 'Transponder Code': Sending state '900158002020048'
[21:23:43][D][uart_debug:114]: <<< 02:30:44:45:37:37:41:39:43:34:32:34:38:33:30:31:31:30:30:30:30:30:30:30:30:30:30:03:FC:03
Here is the config I used:
Config
esphome:
friendly_name: Cat Sensor
esp32:
framework:
type: esp-idf
uart:
- rx_pin: GPIO4
baud_rate: 9600
debug:
text_sensor:
- platform: wl_134
logger:
level: DEBUG
api:
encryption:
key: "*****"
ota:
- platform: esphome
password: "*****"
wifi:
manual_ip:
static_ip: 192.168.1.131
ap:
ssid: "*****"
password: "*****"
captive_portal:
I used the 5V TX in combination with the voltage divider 1kΩ/2kΩ.
Looks like the assumption from @Karosm was correct, and the UART debug doesn’t work with this software version and a ESP32-C6. Thank you very much for your help, I really appreciate it!
Karosm
(Karosm)
January 23, 2025, 10:08pm
35
Nice! I kind of expected the problem was on debug, not on uart.
