Hi
I am running HA in a NUC ubuntu docker following this instructions.
Lately I had problem to watch movies from Stremio so today I tried to fix it (ha ha)
So I tried the following commands (among several tries like uninstall stremio, its addons etc)
There is a red notification in ubuntu desktop which prompts me to check - udpate (?) not sure
I am getting the following which makes me afraid that something is wrong with HA ?
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission d enied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are y ou root?
makis@makis-NUC7PJYH:~$ apt-get update
Reading package lists... Done
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
I did a mistake so I apply the command twice.
Now I am stuck in the picture. It happened before and I dont know how to accept in order to proceed.
makis@makis-NUC7PJYH:~$ sudo apt update && sudo apt upgrade && sudo apt autoremove
[sudo] password for makis:
Hit:1 https://ocean.surfshark.com/debian stretch InRelease
Hit:2 http://gr.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 https://download.docker.com/linux/ubuntu bionic InRelease
Ign:4 http://dl.google.com/linux/chrome/deb stable InRelease
Get:5 http://gr.archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Hit:6 http://dl.google.com/linux/chrome/deb stable Release
Get:7 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Get:8 http://gr.archive.ubuntu.com/ubuntu bionic-backports InRelease [74,6 kB]
Fetched 252 kB in 1s (170 kB/s)
Building dependency tree
Reading state information... Done
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
chromium-codecs-ffmpeg-extra libfwup1
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
ttf-mscorefonts-installer xserver-common xserver-xephyr xwayland
4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 1813 kB/1841 kB of archives.
After this operation, 94,2 kB of additional disk space will be used.
Do you want to continue? [Y/n] makis@makis-NUC7PJYH:~$ sudo apt update && sudo apt upgrade && sudo apt autoremove
Get:7 httAbort.
makis@makis-NUC7PJYH:~$ [sudo] password for makis:
[sudo]: command not found
makis@makis-NUC7PJYH:~$ Hit:1 https://ocean.surfshark.com/debian stretch InRelease
Hit:1: command not found
makis@makis-NUC7PJYH:~$ Hit:2 http://gr.archive.ubuntu.com/ubuntu bionic InRelease
Hit:2: command not found
makis@makis-NUC7PJYH:~$ Hit:3 https://download.docker.com/linux/ubuntu bionic InRelease
Hit:3: command not found
makis@makis-NUC7PJYH:~$ Ign:4 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:4: command not found
makis@makis-NUC7PJYH:~$ Get:5 http://gr.archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Get:5: command not found
makis@makis-NUC7PJYH:~$ Hit:6 http://dl.google.com/linux/chrome/deb stable Release
Hit:6: command not found
makis@makis-NUC7PJYH:~$ Get:7 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Get:7: command not found
makis@makis-NUC7PJYH:~$ Get:8 http://gr.archive.ubuntu.com/ubuntu bionic-backports InRelease [74,6 kB]
Get:8: command not found
makis@makis-NUC7PJYH:~$ Fetched 252 kB in 1s (170 kB/s)
-bash: syntax error near unexpected token `('
makis@makis-NUC7PJYH:~$ Reading package lists... Done
Reading: command not found
makis@makis-NUC7PJYH:~$ Building dependency tree
Building: command not found
makis@makis-NUC7PJYH:~$ Reading state information... Done
makis@makis-NUC7PJYH:~$ 4 packages can be upgraded. Run 'apt list --upgradable' to see them.
makis@makis-NUC7PJYH:~$ Calculating upgrade... Done
Calculating: command not found
makis@makis-NUC7PJYH:~$ The following packages were automatically installed and are no longer required:
Command 'The' not found, did you mean:
command 'the' from deb the
command 'he' from deb node-he
Try: sudo apt install <deb name>
makis@makis-NUC7PJYH:~$ chromium-codecs-ffmpeg-extra libfwup1
chromium-codecs-ffmpeg-extra: command not found
makis@makis-NUC7PJYH:~$ Use 'sudo apt autoremove' to remove them.
Command 'Use' not found, did you mean:
command 'nse' from deb ns2
command 'ase' from deb ase
makis@makis-NUC7PJYH:~$ The following packages will be upgraded:
makis@makis-NUC7PJYH:~$ ttf-mscorefonts-installer xserver-common xserver-xephyr xwayland
ttf-mscorefonts-installer: command not found
makis@makis-NUC7PJYH:~$ 4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
makis@makis-NUC7PJYH:~$ 1 not fully installed or removed.
makis@makis-NUC7PJYH:~$ Need to get 1813 kB/1841 kB of archives.
Command 'Need' not found, did you mean:
command 'seed' from deb seed-webkit2
makis@makis-NUC7PJYH:~$ After this operation, 94,2 kB of additional disk space will be used.
After: command not found
makis@makis-NUC7PJYH:~$ Do you want to continue? [Y/n]
Do: command not found
Hit:2 https://download.docker.com/linux/ubuntu bionic InRelease
Hit:3 http://gr.archive.ubuntu.com/ubuntu bionic InRelease
Get:4 http://gr.archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Ign:5 http://dl.google.com/linux/chrome/deb stable InRelease
Get:6 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Hit:7 http://dl.google.com/linux/chrome/deb stable Release
Fetched 252 kB in 1s (188 kB/s)
Do you want to continue? [Y/n] Y
Get:1 http://gr.archive.ubuntu.com/ubuntu bionic-updates/main amd64 xserver-common all 2:1.19.6-1ubuntu4.4 [27,3 kB]
Get:2 http://gr.archive.ubuntu.com/ubuntu bionic-updates/main amd64 xserver-xephyr amd64 2:1.19.6-1ubuntu4.4 [923 kB]
Get:3 http://gr.archive.ubuntu.com/ubuntu bionic-updates/main amd64 xwayland amd64 2:1.19.6-1ubuntu4.4 [863 kB]
Fetched 1813 kB in 1s (1302 kB/s)
Preconfiguring packages ...
(Reading database ... 210496 files and directories currently installed.)
Preparing to unpack .../ttf-mscorefonts-installer_3.6ubuntu2_all.deb ...
Progress: [ 5%] [###..............................................................................]
2020-04-13 20:46:56 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-13 20:46:56 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-13 20:46:56 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-13 20:46:58 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-13 20:46:58 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for floureon which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-13 20:46:58 WARNING (zeroconf-ServiceBrowser__ewelink._tcp.local.) [custom_components.sonoff] No devicekey for device 100097105d
2020-04-13 20:47:44 WARNING (MainThread) [homeassistant.components.template] Template sensor 'openweather_wind_kmh' has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
2020-04-13 20:54:30 WARNING (MainThread) [hacs.deprecated] The '/community_plugin/*' is deprecated and will be removed in an upcomming version of HACS, it has been replaced by '/hacsfiles/*', if you use the UI to manage your lovelace configuration, you can update this by going to the settings tab in HACS, if you use YAML to manage your lovelace configuration, you manually need to replace the URL in your resources.
I have to admit this ubuntu is very good. I make a relay server to stream videos online https://hdoboxplus.com/. It’s great. If I have any next project, I will use it.
