So I registered here just to ask this question. I got started with this thing on a pi about 2 months ago and muddled my way through setting everything up. I get everything the way I wanted it and now updating to 105.2 from 104.3 breaks so much stuff for my UI.
I had to change my automations because they removed hide_entity and now my UI has so many broken automations not showing up and when I click the little button to edit the UI, my edit button under my groups is gone. I was using that to add and remove stuff from all the groups I have setup (ie automations, lights, switches) on the main page.
No idea what to do now. I go into edit mode but cant edit anything? Help? (And no, I don’t know YAML I just kloodge my way through everything until stuff eventually works… whoever thought of the spacing rules for this language should be beaten with a stick)
See the picture here, I circled where edit used to be, and it go bye bye now.
Yes, there used to be in 104.3, but after I upgraded there isn’t. This view IS after I clicked configure UI and where the edit button used to be. What do I do now?
That’s where they USED to be in 104. I had them on every card I guess its called. Now I don’t have any. I’ve restarted plenty of times and I never have an edit button. The only thing I can do is create new tabs or change the name at the top.
I guess I should have them still, I guess I wipe this out and try starting over again, I thought it was a ‘change’.
