Since Python 3.9 won’t be supported next month, I wanted to upgrade my core install to Python3.10.
However, Python3.10 isn’t included
The first time I tried, I had forgotten to install the libsqlite-dev package so my Python so it couldn’t connect to the database but now I’ve followed the instructions at https://computingforgeeks.com/how-to-install-python-on-debian-linux/ and still, integrations won’t load (I’ve waited 20 minutes for that).
See below the logs (before and after I killed the process)
2023-01-16 10:58:12.048 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-16 11:09:38.766 ERROR (MainThread) [frontend.js.latest.202301100] :0:0 ResizeObserver loop completed with undelivered notifications.
2023-01-16 11:21:50.222 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration midea_ac_lan: Unable to import component: No module named 'Crypto'
2023-01-16 11:21:50.815 ERROR (MainThread) [homeassistant.setup] Error during setup of component application_credentials
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/runner.py", line 120, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 636, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 603, in run_forever
self._run_once()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1868, in _run_once
event_list = self._selector.select(timeout)
File "/usr/local/lib/python3.10/selectors.py", line 469, in select
fd_event_list = self._selector.poll(timeout, max_ev)
KeyboardInterrupt
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/setup.py", line 253, in _async_setup_component
result = await task
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/components/application_credentials/__init__.py", line 150, in async_setup
await storage_collection.async_load()
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/helpers/collection.py", line 245, in async_load
raw_storage = await self._async_load_data()
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/helpers/collection.py", line 241, in _async_load_data
return cast(Optional[dict], await self.store.async_load())
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/helpers/storage.py", line 116, in async_load
return await self._load_task
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/helpers/storage.py", line 125, in _async_load
return await self._async_load_data()
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/helpers/storage.py", line 143, in _async_load_data
data = await self.hass.async_add_executor_job(
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/core.py", line 527, in async_add_executor_job
task = self.loop.run_in_executor(None, target, *args)
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 814, in run_in_executor
self._check_default_executor()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 519, in _check_default_executor
raise RuntimeError('Executor shutdown has been called')
RuntimeError: Executor shutdown has been called
2023-01-16 11:21:50.823 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_text
self.run_forever()
self._run_once()
KeyboardInterrupt
result = await task
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/components/input_text/__init__.py", line 137, in async_setup
2023-01-16 11:21:50.829 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_datetime
self.run_forever()
self._run_once()
KeyboardInterrupt
result = await task
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/components/input_datetime/__init__.py", line 160, in async_setup
2023-01-16 11:21:50.899 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_boolean
self.run_forever()
self._run_once()
KeyboardInterrupt
result = await task
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/components/input_boolean/__init__.py", line 122, in async_setup
2023-01-16 11:21:50.976 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of spotify. Setup failed for dependencies: application_credentials
2023-01-16 11:21:50.977 ERROR (MainThread) [homeassistant.setup] Setup failed for spotify: (DependencyError(...), 'Could not setup dependencies: application_credentials')
2023-01-16 11:21:51.015 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Any door is open for group
self.run_forever()
self._run_once()
KeyboardInterrupt
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/config_entries.py", line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/components/group/__init__.py", line 250, in async_setup_entry
await hass.config_entries.async_forward_entry_setups(
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/config_entries.py", line 1265, in async_forward_entry_setups
await asyncio.gather(
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/config_entries.py", line 1280, in async_forward_entry_setup
result = await async_setup_component(self.hass, domain, self._hass_config)
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/setup.py", line 90, in async_setup_component
return await setup_tasks[domain]
2023-01-16 11:21:51.023 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Any motion sensor for group
self.run_forever()
self._run_once()
KeyboardInterrupt
2023-01-16 11:21:51.072 ERROR (MainThread) [homeassistant.setup] Error during setup of component script
self.run_forever()
self._run_once()
KeyboardInterrupt
result = await task
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/components/script/__init__.py", line 178, in async_setup
await async_get_blueprints(hass).async_populate()
File "/srv/hass-2023/lib/python3.10/site-packages/homeassistant/components/blueprint/models.py", line 360, in async_populate
await self.hass.async_add_executor_job(populate)
2023-01-16 11:21:51.092 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package PyTurboJPEG==1.6.7: ERROR: Operation cancelled by user
