Hi @Blacky
I’ve got a hybrid approach so the point of my internal schedule is to allow my cat feeder to feed regardless of network or home assistant. I use properties in home assistant to control these values in the esphome code, and I can set default values failing being able to get the values from HA at all.
But essentially in order to control the times out of the esphome code I wanted a way to provide them from the HA UI.
This is my current code, I’ve removed my previous attempts with the input_datetime but essentially I had some global variables with default for morning_hour, morning_minute, evening_hour, evening_minute using a text sensor for the date time. This all worked fine, but then casting those to int to use in the on_time hours and minutes, just errorred regardless of what I tried.
I’m not sure if this is the best way to do this or if there is some other way, but using the datetime helper for on_time to me feels like a fairly typical use case.
Here is my code anyway if you’re interested:
esphome:
platform: ESP8266
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "password"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Cat-Feeder Fallback Hotspot"
captive_portal:
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: Cat Feeder ESPHome Version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
name: Cat Feeder IP
ssid:
name: Cat Feeder SSID
bssid:
name: Cat Feeder BSSID
# Sync time with Home Assistant.
time:
- platform: homeassistant
# timezone: Europe//London
on_time:
- hours: 7
minutes: 05
seconds: 45
then:
- if:
condition:
and:
- binary_sensor.is_off: morning_feed_complete
- binary_sensor.is_off: disable_next_feed
- binary_sensor.is_on: morning_feed_enabled
then:
- switch.turn_on: motor
- homeassistant.service:
service: input_boolean.turn_on
entity_id: input_boolean.morning_feed_complete
else:
- if:
condition:
- binary_sensor.is_on: disable_next_feed
then:
service: input_boolean.turn_off
entity_id: input_boolean.disable_next_feed
entity_id: input_boolean.evening_feed_complete
- hours: 17
minutes: 35
seconds: 45
then:
- if:
condition:
and:
- binary_sensor.is_off: evening_feed_complete
- binary_sensor.is_on: evening_feed_enabled
then:
else:
- if:
condition:
then:
# Sensors with general information.
# Uptime sensor.
- platform: uptime
name: Cat Feeder Uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: Cat Feeder WiFi Signal
update_interval: 60s
switch:
- platform: gpio
pin: GPIO3
on_turn_on:
- delay: 60000ms
- switch.turn_off: motor
# Todo do an on turn off that restarts the motor if it has run for < 10 seconds
- platform: restart
name: Cat Feeder Restart
binary_sensor:
- platform: gpio
pin:
number: 5
mode: INPUT_PULLUP
inverted: False
name: "Dispenser Rotating"
on_release:
then:
# Run conditions
name: "Morning Feed Enabled"
entity_id: input_boolean.morning_feed_enabled
name: "Morning Feed Complete"
name: "Evening Feed Enabled"
entity_id: input_boolean.evening_feed_enabled
name: "Evening Feed Complete"
name: "Disable Next Feed"
