Help with using template inside a dictionary
Hi all,
I’m trying to send a dictionary with an embedded template in an automation.
The service call works fine without the template variable but whenever I add the template, I get :
Error: Error rendering data template: Result is not a Dictionary
Here is my automation.
alias: Mqqt Speak to Rhasspy
description: ""
  - platform: mqtt
    topic: Speak
condition: []
  - service: rest_command.rhasspy_tts
    data: "{'text': {{states('sensor.mqtt_speak')}} }"
mode: single
I’ve tested the template
in the Template Editor (Development tab) and it works fine.
Any help is greatly appreciated.
You should define it like this:
      text: "{{ states('sensor.mqtt_speak') }}"
You are currently setting “data” to a string value.
That works great. I was mixing json with yaml, doh.
Thanks for the help.
