poldim
January 18, 2022, 4:29pm
1
I’ve got a somewhat complex TOU rate from my utility. I’d like to make a sensor that can tell me what
I tried to search solutions from others and found this . I like how it first considers the holidays, but it’s still a bit too simple on the month/day of week/time of day logic.
Does anyone have an example for this?
AllHailJ
(J Gent)
January 18, 2022, 6:50pm
2
Have you considered using the workday binary_sensor.
In your configuration.yaml
#set up workdays - https://www.home-assistant.io/integrations/workday
binary_sensor:
- platform: workday
country: USA
workdays: [mon, tue, wed, thu, fri]
excludes: [sat, sun, holiday]
setup an energy season sensor
- name: "Energy Season"
unique_id: "energy_season"
state: >
{% if now().month in [6,7,8,9] %}
summer
{% else %}
winter
{% endif %}
Then you can setup the energy sensor
- name: "Energy Price"
unique_id: "energy_price"
state: >-
{% if states('sensor.energy_season') == "summer" %}
{% if states('binary_sensor.workday_sensor') and (17 <= now().hour <=20) %}
0.12 Peak Rate
{% elif states('binary_sensor.workday_sensor') and ((14 <= now().hour <=15) or (20 <= now().hour <=21))) or (now().day in [6,7] and (17 <= now().hour <=19)) %}
0.10 Parital-Peak Rate
{% else %}
0.08 Off Peak Rate
{% endif %}
{% else %}
{% if states('binary_sensor.workday_sensor') and (17 <= now().hour <=19) %}
{% else %}
0.08 Off-Peak Rate
{% endif %}
{% endif %}
unit_of_measurement: USD/kWh
Here it is in the developer tools. I put the text by the rate so I wouldn’t lose track of where I was. These will need removal from the sensor.
I think I have all of the indentations and quoting correct. I can’t check on my system but this should get you there.
EDIT: found a way to test and added the corrections to make it function. Fixed the times
AllHailJ
(J Gent)
January 21, 2022, 5:48pm
3
Here it is cleaned up and using only one sensor.
# For peak demand pricing
state: >-
{% set wd = states('binary_sensor.workday_sensor') %}
{% set hr = now().hour %}
{% if (now().month in [4,5,6,7,8,9]) %}
{% if wd and (16 <= now().hour < 21) %}
0.121
{% elif (wd and (14 <= hr < 16) or (20 <= hr < 22)) or (now().day in [6,7] and (17 <= hr < 20)) %}
0.101
{% else %}
0.081
{% endif %}
{% else %}
{% if wd and (17 <= hr < 20) %}
0.102
{% else %}
0.082
{% endif %}
{% endif %}
unit_of_measurement: "USD/kWh"
EDIT: fixed list for summer. @poldim please see the change in months
