I’m struggling with setting up a mqtt battery sensor to use in a Lovelace Picture card. I simply want to see “Battery: 87%” and not only the state.
Thats the working mqtt sensor, but the value is only "34%"
But remember, if you do this, you will not be able to graph the data. It will treat it as a string. That’s why unit_of_measurement is omitted at this point, because it doesn’t matter.
You also won’t be able to treat it as a battery device_class. So your icon will not change based on the % of battery.
Is that picture elements? If so, just make another sensor with the word battery:. Or you could use an icon element to show the battery symbol and then have the percent next to it.
