I have a tab in Lovelace that contains all of my weather data from my PWS, NOAA tides, forecasts from OpenWeatherMap, and a static NEXRAD image (from Weather Radar Maps on HACS). I want to add one more picture card, the current surface plot from NOAA’s Aviation Weather Center (AWC - Prog Charts).
In configuration.yaml, I have a scrape sensor defined:
If I look in History, it is accurately pulling the internal URL for the current image (/data/products/progs/20221202/20221202_12_F000_wpc_sfc.gif). I’ve fiddled with the template editor in developer’s tools, and have come up with the following template:
which correctly shows the full URL, that if put into a browser, displays the image I want in a card.
And here is where I am stuck, I have tried to enter that code into the picture card, but I don’t think the image path can accept a template. I’m kind of hitting the limit of my research at this point, and am looking to the community for help!
The picture is updated every three hours by NOAA’s Aviation Weather Center, so I wanted it to just scrape the web address and display the current picture on their site - without downloading a picture every 3 hours.
I ended up finding the answer. I found the Lovelace Card Templater on HACS. After installing that, here’s my code for the Lovelace card in case anyone wants to do something similar…
I’m trying to achieve the same thing, but without success. I have a scrape entity with the image URL as state, which appears correctly when checked in dev tools => template.
