Help with Xiaomi SSM-U01
Hello everybody,
using Zigbee2MQTT, I recently bought this device : https://www.zigbee2mqtt.io/devices/SSM-U01.html#xiaomi-ssm-u01
Paired, discovered without problem. Switch works OK, everything well created in HA.
But! sensors for energy and power always say Null.
Anybody gets same problem ? Any idea about solution ? Great thanks by advance !
"home_assistant": {
    "installation_type": "Home Assistant Supervised",
    "version": "2023.2.5",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.10.7",
    "docker": true,
    "arch": "x86_64",
    "timezone": "Europe/Paris",
    "os_name": "Linux",
    "os_version": "5.10.0-19-amd64",
    "supervisor": "2023.01.1",
    "host_os": "Debian GNU/Linux 11 (bullseye)",
    "docker_version": "20.10.20",
    "chassis": "vm",
    "run_as_root": true
I do have the same device using sky connect
 doesn’t even recognise it’s a switch
Is recognised as a “Router” and reports Temperature only (which seems to be wrong “0.1 Degree”)
Any Ideas?
If you are using ZHA you need to install a quirk to get it to work as a switch.
Either way, I’ve also never got the power monitoring to work.
I found many issues about that device in Zigbee2MQTT Github :
Seems we should not have much hope to make it work.
After removing it from HA (i.e. from the ZigBee Network) and rediscovering it again it works
 Same happened with the 2nd identical device (First discovery was faulty
That worked for me aswell. Thanks for the tip!
Did anyone managed to get it working (beyond the pure switch command) on ZHA?
Form the latest messages, it seems to work for a few individuals, but not sure it is ZHA or Z2M integrations.
Stupid me when I opened this topic. Device was connected on wires where nothing happened, so didn’t show any energy nor power, normal. Moved id, now works fully OK with Z2M integration.
