Hi
I have a switch in my setup called switch.bedroom_addressable_led_relay_switch
and the state can be either on
or off
I also have the wall panel mod to set the dashboard (called called lovelace-test1
) in kiosk mode and so show a screensaver after 15 seconds of inactivity.
After the screensaver stops I am trying to set the screensaver_stop_navigation_path:
to a lovelace dashboard depending on the state of the switch.bedroom_addressable_led_relay_switch
If the state of the switch is off
I would like the screensaver_stop_navigation_path:
to be /lovelace-test1/lighting
, and if the state of the switch is on
, to be /lovelace-test1/lighting-on
I am hoping I could do this without using templates and just via the YAML for the dashboard where the screensaver_stop_navigation_path:
is set for the wall panel mod.
Here is the code I am using, but it isn’t working.
title: Test1
wallpanel:
enabled: true
hide_toolbar: true
hide_sidebar: true
fullscreen: true
idle_time: 15
fade_in_time: 5
display_time: 0
screensaver_stop_navigation_path: |
if (states['switch.bedroom_addressable_led_relay_switch'].state == 'off') return '/lovelace-test1/lighting'; return '/lovelace-test1/lighting-on';
What the code above does is set the screensaver_stop_navigation_path:
to:
/lovelace-test1/[[[%20%20if%20(states[%22switch.bedroom_addressable_led_relay_switch%22].state%20==%20%22off%22)%20%20return%20%22/lovelace-test1/lighting%22;%20%20return%20%22/lovelace-test1/[[[%20%20if%20(states[%22switch.bedroom_addressable_led_re...
and hence fails to set the dashboard depending on the state of the switch.
Thanks in advance for any help, Kal.
