after going through them i get the following on the log: homeassistant.components.zwave: You are missing required dependency Python Open Z-Wave. Please follow instructions at: https://home-assistant.io/components/zwave/ homeassistant.bootstrap: component zwave failed to initialize
Right now i am wondering what to possibly do next. Was the install of OpenZwave not successful? is this an issue with my configuration.yaml?
Thanks for the reply. a few questions come to mind. That post is great but it talks about âCompiling open-zwave-control-panelâ. The page and instructions i was following was to âcompile the OpenZWave library and install the related python-OpenZWave packageâ
Are these the same thing? from reading that post he talks about diagnosing devices and i cant even get to that point, at least that is what i think based on the errors in my log(ABOVE).
So then youâve already followed these instructions then?
If you used the AIO installer, all of this is done for you automatically. If you didnât, consider wiping and using it as this is the fastest path to getting your setup up and running.
Yes i followed those instructions. and right after even before i put the USB stick in the pi i got the error i put in my original post. This might be worth mentioning. after the install i went to the location on the pi that the config says and i do not have a config there:
/usr/local/share/python-openzwave/config
That location does not exist. PRE NOR POST install following the instructions.
Okay a much bigger question. Do most people use the AIO installer? does it just work right away? i am new to linux/zwave/pi/HA so it has taken me a lot of time to get to this point, so if i do decide to dump everything and start again i want to make sure i am further along than i am now.
where can i locate the AIO and instructions for the PI?
I went from a Windows 10 installation to a Pi using the AIO installer. I had never even seen a Pi before and this was my first exposure to it. I followed all of the instructions in this video from @brusc
and everything worked straight off. I then moved over my configs from the Win10 box and made some necessary adjustments and I havenât really had any major issues (that I havenât caused myself!) since I did. For a Pi/Linux noob like myself, this was really impressive. I think it might be the best route for you to go as well.
Itâs really easy to follow; I watched it once, then I ordered my parts from Benâs links to support his work and waited for delivery. Then I got everything put together, put a keyboard, mouse and monitor on the Pi and watched his video on my PC and paused for each step. It really couldnât have been easier. And since itâs all automated for you, you donât have to worry about compiling openzwave or the control panel - everything is preconfigured. Whatâs more, the default installs it in a virtual environment so no matter what other stuff you install on the Pi, the HA instance and itâs dependencies wonât be touched. Thatâs the best part!
Hey messing about is how we learn though, right? Iâve been trying to get the Harmony-API working for a about two weeks now, someone showed me how to get npm installed and I kept mucking about with the scripts not working. Gave up for awhile. Then tonight I tried again and realized the error message in the install script was telling me I had the wrong version of npm installed. Googled how to update it, updated and re ran the install and voila!
But messing with your working HA install is much more fun than messing with trying to get it installed, so Iâd wipe the disk and start fresh with the AIO installer. Keep me posted if I can help.
@rpitera just wanted to say thanks again for the direction. Got everything reinstalled and then just plugged the USB and it worked right away.
Another question if you have time. How do i change the label on the ZWave item? right now in HA it just says âLightâ. its a GE 12724 3-Way Dimmer Switch. Id like it to say Office Lights or anything different so i do not confuse it once i install my other switches.
You can do this with a customization entry; first you need to know the internal name that HA gives the device, which you can find in the States panel in the dev tools (on your hamburger menu, at the bottom, looks like <>).
