I have an Aeotech Z-Stick and have many Z-wave devices paired without issue. I have three Dome door/window sensors paired and are working well. I am running HassIO. I just received three more Dome door/window sensors and I am having tons of issues. I tried pairing them one after another to avoid restarting home assistant a bunch of times. That seems to have caused some issue, I can’t get any of them to work. They are showing up as Node:XX Probe at this point. I can’t remove them as failed nodes. Also, the Node number seems to be offset by 1 when looking at the higher numbered node in the OZW section of the frontend and looking at the latest entry in entity_registry.yaml.
I tried resetting the sensors to their factory defaults, nothing seems to help. Any suggestions?
I have restarted over and over again. I have never done a secure add on any z-wave device. I have almost 30 of them. I seem to have one working now, but I am having trouble renaming it. I just got this:
WARNING (MainThread) [homeassistant.core] Unable to find service zwave/rename_node
