I purchased 2 zigbee dimmers and had them installed.
The dimmer switch purchased is this one:
and I presume it is the same as this one, for reference:
One of them was installed to dim the lights on a chandelier. The chandelier has standard icandescent globes, totally around 350W and the dimmer works fine. The dimming function works perfectly by touching the up/down arrows on the switch, and by sliding the slider in HA, and even shows the percentage dimming.
The other dimmer was installed to dim 6 LED downlights. The LED downlights are these:
https://www.bunnings.com.au/click-8w-90mm-cct-led-downlight_p0516233
https://www.bunnings.com.au/click-8w-90mm-cct-led-downlight-12-pack_p0516232
Prior to having the zigbee dimmer switch installed, I had the LED downlights running off a conventional dimmer:
https://www.bunnings.com.au/deta-200w-universal-electronic-dimmer-with-x6-series-wall-switch_p0098354
and the worked and dimmed perfectly!
After having the zigbee dimmer installed (ie replacing the old rotary knob and switch), I am now unable to dim the LED downlights. They come on at full brightness and pressing the up/down arrows on the switch dont have any effect on the brightness. When I do press the up/down arrows the the brightness intensity percentage changes in HA, so I know that the light switch is working. I can also adjust the slider in HA, but the brightness of the LED’s doesn’t change.
Can someone please help how I can solve this problem? I’m tempted to go out and buy alternative downlights, but this may not solve the problem.
Thanks in advance for your help.
