Hi everyone, I got my first device with zigbee - Zemismart ZM-CSW002-D (curtain switch)
I use usb stick CC2531 like a coordinator. I have installed mqtt broker and zigbee2mqtt via Supervisor.
My coordinator CC2531 is installed correctly, but I have promlem with Zemismart ZM-CSW002-D (SM-SW101-ZC)
It has a message:
NO COMPONENTS Maybe this device is not (yet) supported by Zigbee2Mqtt?
I have set the following settings:
data_path: /share/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://core-mosquitto'
user: mqtt_user
password: mqtt_password
serial:
port: /dev/ttyACM0
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental:
new_api: true
socat:
enabled: false
master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
restartdelay: 1
initialdelay: 1
options: '-d -d'
log: false
zigbee_shepherd_devices: true
What am I doing wrong?
Hello everyone, I solved my problem.
Perhaps this will help new users like me.
I followed this instruction https://www.zigbee2mqtt.io/how_tos/how_to_support_new_devices.html
I added a file divices.js in share\zigbee2mqtt and put this config into it:
zigbeeModel: ['TS130F'],
fingerprint: [
{modelID: 'TS130F', manufacturerName: '_TZ3000_8kzqqzu4'}
model: 'SC400',
vendor: 'Loratap',
description: 'Curtain switch',
supports: 'open, close, stop, position',
fromZigbee: [fz.cover_position_tilt, fz.ignore_basic_report],
toZigbee: [tz.cover_state, tz.cover_position_tilt],
meta: {configureKey: 1, coverInverted: true},
Next step, I added this config into configuration.yaml
cover:
- platform: "mqtt"
availability_topic: "zigbee2mqtt/bridge/state"
command_topic: "zigbee2mqtt/<FRIENDLY_NAME>/set"
value_template: "{{ value_json.position }}"
set_position_template: "{ \"position\": {{ position }} }"
set_position_topic: "zigbee2mqtt/<FRIENDLY_NAME>/set"
position_topic: "zigbee2mqtt/<FRIENDLY_NAME>"
- platform: "mqtt"
state_topic: "zigbee2mqtt/<FRIENDLY_NAME>"
unit_of_measurement: "lqi"
value_template: "{{ value_json.linkquality }}"
icon: "mdi:signal"
Now I have a question, how can I calibrate my curtain switch?
I found the following tables: https://github.com/dresden-elektronik/deconz-rest-plugin/issues/2999
This is not for HA, but I suppose the addresses should be the same.
I need to increase the opening and closing time to 45 seconds. Now it is 10 seconds.
Same problem here.
I have the curtain switch, operates well, but only for 10 seconds in both directions.
HELP!
Kilwater
(Kilwater)
January 1, 2021, 12:44pm
5
Hey! Have you found any solution for calibrating the switch yet?
Hi. I have not resolved this problem
sallwm
February 25, 2021, 7:48am
7
Have anyone fixed this issue?
