Thanks,
I think the binary setting is not for the Fibaro sensor but I´ll check again since it seems that the temperature is actually updating. It is just slow.
So my problem is with movement.
Yes, I noticed that I need to wake it up to change config in OZCP.
I hope you don’t mind but I altered your post title to make it a bit more specific. There’s a few things that are unique about the Fibaro Multi motion sensor from observing posts here on the subject and I felt that this would get you some more help from users that have solved them.
It’s been my experience with adding new devices that it takes a little time and a few restarts before the naming conventions settle in. I always wait a restart or two before adding any new devices to my setup.
