I’m struggling using templates and would appreciate if someone could give some help on the syntax needed.
I have a Shelly device I want to use to monitor when the power for a machine is turned on. When the machine is off and the device is “Unavailable” I want a Template Binary Sensor to report “OK”.
When the machine is turned on (and the connected Shelly device is powered on and connect to the wifi) I want the Template Binary Sensor to show “Problem”. I shouldn’t matter if the Shelly device is turned on or off, just that it’s available again.
I have figured out the Template Binary Sensor should have device_class: problem. I don’t understand how the rest of the condition should look like.
platform: template
sensors:
burner:
friendly_name: "Burner"
value_template: "{{ if is_state ('switch.shelly_shsw_1_ba20d9', '') }}"
platform: template
sensors:
burner:
value_template: "{{ not is_state('switch.shelly_shsw_1_ba20d9', 'unavailable') }}"
This binary sensor will be ‘on’ (shows ‘problem’ in the frontend) when the shelly is NOT unavailable and will be ‘off’ (shows ‘OK’ in the frontend) when the shelly is unavailable.
