I am new to HA and am migrating from Wink. I specifically want to have Alexa routine to be triggered off one the z-wave wink motion sensors. I have added the sensor successfully and I see it “registering” motion correctly in HA. I have been able to share states with Alexa thru the Cloud service. The hickup I have is the wink motion sensor does not have a defined device class. I cannot see where I can add this so that Alexa will see this sensor as a “Motion” sensor and not just “Other”. Please help, or refer me to the material I need to go over. I have been able to “Set State” and add that line in the yaml code but it seams to not stay configured. I cannot see where I can edit this
In the configuration and from there select customize menu. /config/customize
Thank you taikapanu. I guess I didn’t see how I add the line to the config > then I can access the GUI menu for configuration of entities. I think I have it all working now. I really appreciate it.
