I am trying to migrate to HA.
I am using rpi3+ zme_uzb1 stick.
After adding a fibaro relay with success ( node50:complete), and adding a button to lovelace dashboard, i can see the button changes it’s state when using the physical button.
but when I try to use the button on the dashboard nothing happens, and there is a line in the log “node presumed dead” even though it is still getting information from the device.
I have tried troubleshooting it with a different relay and i am getting the same result.
i will appreciate any kind of advice
log:
2020-04-29 17:00:30.372 Info, Node050, Response RTT 7093 Average Response RTT 5092
2020-04-29 17:00:30.372 Info, Node050, Received SwitchBinary report from node 50: level=Off
2020-04-29 17:00:30.372 Detail, Node050, Refreshed Value: old value=true, new value=false, type=bool
2020-04-29 17:00:30.372 Detail, Node050, Changes to this value are not verified
2020-04-29 17:00:30.372 Detail, Node050, Notification: ValueChanged
2020-04-29 17:00:30.438 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x32, 0x03, 0x25, 0x03, 0x00, 0xd8, 0x00, 0x3f
2020-04-29 17:00:30.439 Detail,
2020-04-29 17:00:30.439 Info, Node050, Response RTT 7159 Average Response RTT 6125
2020-04-29 17:00:30.439 Info, Node050, Received SwitchBinary report from node 50: level=Off
2020-04-29 17:00:30.439 Detail, Node050, Refreshed Value: old value=false, new value=false, type=bool
2020-04-29 17:00:30.439 Detail, Node050, Changes to this value are not verified
2020-04-29 17:00:30.439 Detail, Node050, Notification: ValueChanged
2020-04-29 17:00:30.503 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x32, 0x03, 0x25, 0x03, 0x00, 0xd7, 0x00, 0x30
2020-04-29 17:00:30.503 Info, Node050, Response RTT 7224 Average Response RTT 6674
2020-04-29 17:00:30.503 Info, Node050, Received SwitchBinary report from node 50: level=Off
2020-04-29 17:00:30.503 Detail, Node050, Refreshed Value: old value=false, new value=false, type=bool
2020-04-29 17:00:30.503 Detail, Node050, Changes to this value are not verified
2020-04-29 17:00:30.503 Detail, Node050, Notification: ValueChanged
2020-04-29 17:00:30.526 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x32, 0x03, 0x25, 0x03, 0x00, 0xd7, 0x00, 0x30
2020-04-29 17:00:30.526 Info, Node050, Response RTT 7247 Average Response RTT 6960
2020-04-29 17:00:30.526 Info, Node050, Received SwitchBinary report from node 50: level=Off
2020-04-29 17:00:30.526 Detail, Node050, Refreshed Value: old value=false, new value=false, type=bool
2020-04-29 17:00:30.526 Detail, Node050, Changes to this value are not verified
2020-04-29 17:00:30.527 Detail, Node050, Notification: ValueChanged
2020-04-29 17:00:30.574 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x32, 0x03, 0x25, 0x03, 0x00, 0xd7, 0x00, 0x30
2020-04-29 17:00:30.574 Info, Node050, Response RTT 7295 Average Response RTT 7127
2020-04-29 17:00:30.575 Info, Node050, Received SwitchBinary report from node 50: level=Off
2020-04-29 17:00:30.575 Detail, Node050, Refreshed Value: old value=false, new value=false, type=bool
2020-04-29 17:00:30.575 Detail, Node050, Changes to this value are not verified
2020-04-29 17:00:30.575 Detail, Node050, Notification: ValueChanged
2020-04-29 17:00:30.601 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x32, 0x03, 0x25, 0x03, 0x00, 0xd5, 0x00, 0x32
2020-04-29 17:00:30.601 Info, Node050, Response RTT 7322 Average Response RTT 7224
2020-04-29 17:00:30.601 Info, Node050, Received SwitchBinary report from node 50: level=Off
2020-04-29 17:00:30.601 Detail, Node050, Refreshed Value: old value=false, new value=false, type=bool
2020-04-29 17:00:30.601 Detail, Node050, Changes to this value are not verified
2020-04-29 17:00:30.601 Detail, Node050, Notification: ValueChanged
2020-04-29 17:00:30.627 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x32, 0x03, 0x25, 0x03, 0x00, 0xd5, 0x00, 0x22
2020-04-29 17:00:30.627 Info, Node050, Response RTT 7348 Average Response RTT 7286
2020-04-29 17:00:30.627 Info, Node050, Received SwitchBinary report from node 50: level=Off
2020-04-29 17:00:30.628 Detail, Node050, Refreshed Value: old value=false, new value=false, type=bool
2020-04-29 17:00:30.628 Detail, Node050, Changes to this value are not verified
2020-04-29 17:00:30.628 Detail, Node050, Notification: ValueChanged
2020-04-29 17:00:33.280 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-29 17:00:33.280 Detail, Node050, Removing current message
2020-04-29 17:00:33.280 Detail, Node050, Notification: Notification - TimeOut
2020-04-29 17:00:33.284 Detail, Node050, Query Stage Complete (Session)
2020-04-29 17:00:33.284 Detail, Node050, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2020-04-29 17:00:33.285 Detail, Node050, QueryStage_Dynamic
2020-04-29 17:00:33.285 Detail, Node050, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Get (Node=50): 0x01, 0x0d, 0x00, 0x13, 0x32, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x02, 0x25, 0x13, 0xa9
2020-04-29 17:00:33.285 Detail, Node050, Queuing (Send) MultiChannel Encapsulated (instance=2): SwitchBinaryCmd_Get (Node=50): 0x01, 0x0d, 0x00, 0x13, 0x32, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x14, 0xad
2020-04-29 17:00:33.285 Detail, Node050, Queuing (Query) Query Stage Complete (Dynamic)
2020-04-29 17:00:33.285 Info, Node050, Sending (Send) message (Callback ID=0x13, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Get (Node=50): 0x01, 0x0d, 0x00, 0x13, 0x32, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x02, 0x25, 0x13, 0xa9
2020-04-29 17:00:33.294 Detail, Node050, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-29 17:00:33.295 Detail, Node050, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-29 17:00:34.307 Detail, Node050, Received: 0x01, 0x05, 0x00, 0x13, 0x13, 0x01, 0xfb
2020-04-29 17:00:34.308 Detail, Node050, ZW_SEND_DATA Request with callback ID 0x13 received (expected 0x13)
2020-04-29 17:00:34.308 Info, Node050, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-04-29 17:00:34.308 Warning, Node050, WARNING: Device is not a sleeping node.
2020-04-29 17:00:34.308 Detail, Node001, Expected callbackId was received
2020-04-29 17:00:38.320 Detail, Node050, Received: 0x01, 0x05, 0x00, 0x13, 0x13, 0x01, 0xfb
2020-04-29 17:00:38.320 Detail, Node050, ZW_SEND_DATA Request with callback ID 0x13 received (expected 0x00)
2020-04-29 17:00:38.320 Warning, Node050, WARNING: Unexpected Callback ID received
2020-04-29 17:00:42.343 Detail, Node050, Received: 0x01, 0x05, 0x00, 0x13, 0x13, 0x01, 0xfb
2020-04-29 17:00:42.343 Detail, Node050, ZW_SEND_DATA Request with callback ID 0x13 received (expected 0x00)
2020-04-29 17:00:42.343 Warning, Node050, WARNING: Unexpected Callback ID received
2020-04-29 17:00:43.286 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-29 17:00:43.286 Detail, Node050, Removing current message
2020-04-29 17:00:43.287 Detail, Node050, Notification: Notification - TimeOut
2020-04-29 17:00:43.290 Detail,
2020-04-29 17:00:43.290 Info, Node050, Sending (Send) message (Callback ID=0x14, Expected Reply=0x04) - MultiChannel Encapsulated (instance=2): SwitchBinaryCmd_Get (Node=50): 0x01, 0x0d, 0x00, 0x13, 0x32, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25, 0x14, 0xad
2020-04-29 17:00:43.299 Detail, Node050, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-29 17:00:43.299 Detail, Node050, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-29 17:00:50.314 Detail, Node050, Received: 0x01, 0x05, 0x00, 0x13, 0x14, 0x01, 0xfc
2020-04-29 17:00:50.314 Detail, Node050, ZW_SEND_DATA Request with callback ID 0x14 received (expected 0x14)
2020-04-29 17:00:50.314 Info, Node050, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-04-29 17:00:50.315 Warning, Node050, WARNING: Device is not a sleeping node.
2020-04-29 17:00:50.315 Detail, Node001, Expected callbackId was received
2020-04-29 17:00:53.291 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-04-29 17:00:53.291 Detail, Node050, Removing current message
2020-04-29 17:00:53.291 Detail, Node050, Notification: Notification - TimeOut
2020-04-29 17:00:53.295 Detail, Node050, Query Stage Complete (Dynamic)
2020-04-29 17:00:53.295 Detail, Node050, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-04-29 17:00:53.295 Detail, Node050, QueryStage_Configuration
2020-04-29 17:00:53.295 Detail, Node050, QueryStage_Complete
2020-04-29 17:00:53.295 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2020-04-29 17:00:53.295 Detail, Node050, Notification: NodeQueriesComplete
2020-04-29 17:01:09.057 Info, Node050, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2020-04-29 17:01:09.057 Info, Node050, SwitchBinary::Set - Setting node 50 to On
2020-04-29 17:01:09.057 Detail, Node050, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Set (Node=50): 0x01, 0x0e, 0x00, 0x13, 0x32, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x01, 0xff, 0x25, 0x15, 0x51
2020-04-29 17:01:09.057 Detail, Node050, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Get (Node=50): 0x01, 0x0d, 0x00, 0x13, 0x32, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x02, 0x25, 0x16, 0xac
2020-04-29 17:01:09.058 Detail,
2020-04-29 17:01:09.058 Info, Node050, Sending (Send) message (Callback ID=0x15, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Set (Node=50): 0x01, 0x0e, 0x00, 0x13, 0x32, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x01, 0xff, 0x25, 0x15, 0x51
2020-04-29 17:01:09.070 Detail, Node050, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-04-29 17:01:09.070 Detail, Node050, ZW_SEND_DATA delivered to Z-Wave stack
2020-04-29 17:01:15.074 Detail, Node050, Received: 0x01, 0x05, 0x00, 0x13, 0x15, 0x01, 0xfd
2020-04-29 17:01:15.075 Detail, Node050, ZW_SEND_DATA Request with callback ID 0x15 received (expected 0x15)
2020-04-29 17:01:15.075 Info, Node050, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-04-29 17:01:15.075 Warning, Node050, WARNING: Device is not a sleeping node.
2020-04-29 17:01:15.075 Error, Node050, ERROR: node presumed dead
2020-04-29 17:01:15.075 Detail, Node001, Expected callbackId was received
2020-04-29 17:01:15.075 Detail, Node001, Expected reply was received
2020-04-29 17:01:15.075 Detail, Node001, Message transaction complete
2020-04-29 17:01:15.075 Detail, Node050, Removing current message
2020-04-29 17:01:15.075 Detail, Node050, Notification: Notification - Node Dead
2020-04-29 17:01:15.079 Error, Node050, ERROR: Dropping command because node is presumed dead
2020-04-29 17:01:15.079 Detail, Node050, Removing current message
2020-04-29 17:03:31.245 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x32, 0x03, 0x25, 0x03, 0xff, 0xc9, 0x00, 0xd1
2020-04-29 17:03:31.245 Error, Node050, WARNING: node revived
2020-04-29 17:03:31.245 Info, Node050, Received SwitchBinary report from node 50: level=On
2020-04-29 17:03:31.245 Detail, Node050, Refreshed Value: old value=false, new value=true, type=bool
2020-04-29 17:03:31.246 Detail, Node050, Changes to this value are not verified
2020-04-29 17:03:31.246 Detail, Node050, Notification: Notification - Node Alive
2020-04-29 17:03:31.249 Detail, Node050, Notification: ValueChanged
2020-04-29 17:03:31.310 Detail, Node050, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x32, 0x03, 0x25, 0x03, 0xff, 0xd7, 0x00, 0xcf
