Help Zigbee2mqtt new user
Hello everyone !
I’m new to Home Assistant and could really use some help with an issue I’m having integrating Zigbee2MQTT. When I check the logs, I’m getting the following messages:
[16:08:58] INFO: Preparing to start...
[16:08:59] INFO: Socat not enabled
[16:08:59] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2024-04-18 16:09:01: Logging to console and directory: '/config/zigbee2mqtt/log/2024-04-18.16-09-01' filename: log.txt
Zigbee2MQTT:info  2024-04-18 16:09:01: Starting Zigbee2MQTT version 1.36.1 (commit #unknown)
Zigbee2MQTT:info  2024-04-18 16:09:01: Starting zigbee-herdsman (0.40.3)
Zigbee2MQTT:error 2024-04-18 16:10:11: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-04-18 16:10:11: Failed to start zigbee
Zigbee2MQTT:error 2024-04-18 16:10:11: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-04-18 16:10:11: Exiting...
Zigbee2MQTT:error 2024-04-18 16:10:12: Error: Failure to connect
    at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:373:19)
    at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:171:13)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
    at Zigbee.start (/app/lib/zigbee.ts:62:27)
    at Controller.start (/app/lib/controller.ts:109:27)
    at start (/app/index.js:107:5)
I’ve tried following various tutorials and troubleshooting from similar discussions, but none of the suggested solutions seem to work in my case. Here are some additional details:
*** I’m using a Sonoff Dongle-Plus model P (only in zigbee) with a Raspberry Pi 5 (8GB of RAM).**
*** I’m connecting to the Sonoff dongle via a USB 3.0 extension.**
*** I followed the tutorial link to YouTube tutorial, which I found excellent, removing ZHA, creating a user, installing Mosquitto Broker, Zigbee2MQTT, and configuring MQTT.**
My configuration settings are as follows:
MQTT:
  • base_topic: zigbee2mqtt
  • user: mqtt_user
  • password: omar1234
  • server: mqtt://core-mosquitto:1883
Serial:
  • port: /dev/ttyUSB0 (I also tried with the full ID without success)
  • adapter: ezsp
I’ve enabled advanced mode and restarted Home Assistant, but the issue persists. If anyone has any ideas or suggestions on how to resolve this problem, I would greatly appreciate your help
Wrong. A Dongle P needs
serial:
  adapter: zstack
Hi Francis,
First of all, thank you for your response.
I believe I have the Dongle-P you suggested.
Here is a photo of the box.
Indeed, a Dongle-P, so change your Zigbee2MQTT configuration accordingly .
I just modified the adapter to ‘zstack’.
I restarted my HA, but it’s still the same.
[18:04:35] INFO: Preparing to start...
[18:04:35] INFO: Socat not enabled
[18:04:36] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2024-04-18 18:04:38: Logging to console and directory: '/config/zigbee2mqtt/log/2024-04-18.18-04-38' filename: log.txt
Zigbee2MQTT:info  2024-04-18 18:04:38: Starting Zigbee2MQTT version 1.36.1 (commit #unknown)
Zigbee2MQTT:info  2024-04-18 18:04:38: Starting zigbee-herdsman (0.40.3)
Zigbee2MQTT:error 2024-04-18 18:05:48: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-04-18 18:05:48: Failed to start zigbee
Zigbee2MQTT:error 2024-04-18 18:05:48: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-04-18 18:05:48: Exiting...
Zigbee2MQTT:error 2024-04-18 18:05:48: Error: Failure to connect
You need to restart Zigbee2MQTT. Zigbee2MQTT is still trying to load a Dongle-E.
I’ve already restarted Zigbee2MQTT and HA. Unfortunately, I don’t have a dongle E. That’s why I turned to the forum.
It seems like the P dongle isn’t compatible, even though the documentation states that it should work…
The Dongle-P (and all other Ti-based (CC2652) dongles) are the only dongles that are fully supported by Zigbee2MQTT. All other chipsets (including the Dongle-E) are still ‘experimental’.
Show your Zigbee2MQTT configuration as it is now.
As Francisp mention, this do work. Try full ID and no adapter, like this.
Directly from my configuration
serial:
  port: >-
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d617560171d9eb11bf30158e6fe9f4d9-if00-port0
Are you sure ZHA is not installed ?
Here are screenshots of my entire configuration. I’ve tried without the adapter, but it doesn’t make any difference.
Should work. Is the dongle connected to a USB 2 port ?
Yes, that’s indeed the case.
You didn’t add the adapter type in the config. Needs to be zstack.
Then I’m totally lost why Zigbee2MQTT still wants to load ezsp
Maybe update the firmware to 20230507 ?
Incredible, it finally works! It took adding the zstack and connecting the Sonoff key directly to the RPI5 without using the usb extension (it’s a 3.0 extension). Thank you so much for all your help!
Remember to get a new USB extension cable, otherwise your network will, most probably, be unstable when you connect a lot of devices.
