Helper changes device class
Hello!
I have a 3-phase water boiler which energy consumption I measure using Shelly 3EM. I am able to measure individual phases in the energy dashboard, but whenever I use a helper to sum the 3 phases together, it gives an error when adding the total-sensor to the energy dashboard:
“Unexpected device class”
I just add the 3 energy values of the 3EM with SUM in the helper section.
I find it hard to find the helper configuration in the yaml files to check or modify the device class.
Anyone else having the same problem?
I also measure my total consumption from the grid using the same 3-phase 3EM. In the energy dashboard, adding the 3 phases separately adds them together and works, but again it’s impossible to add a “total” energy sum from helper sum-sensor.
Look in Developer Tools → States. What device class is listed for your helper?
If you need to you can change it with Customize.
Thank you tom,
It seems that the summing in the helper is not keeping the device class in the measurement, hence rendering it useless in energy panel. I was able to manually add a class to the summed-up helper- and the unexpected device error is gone. Anyhow, the energy panel is still compaining “last_reset is missing”. Do I need to further modify the helper somehow?
You probably need to add state_class: total_increasing as well.
Hi, had the same issue.
Thanks for you both for your hints. It is now running like expected with the following configuration:
homeassistant:
  customize:
    sensor.ENTITYNAME:
      device_class: energy
I am trying to do the same for recording the power consumption of my heat pump. The Shelly 3em measures power. Shouldn’t state_class be power, then?
For the energy I am planning on using the Riemann sum.
Yes. For power sensors use the device class power and state class measurement.
Thanks, I have EXACTLY the same use case :slight_smile:
I hoped there was another way but ended up with the yaml solution.
Check this feature request:
