How does this work ? I want daily Min. temp , but I only get present temp
It might help if you tell up which helper type that is.
The Min/Max integration consumes the state from other sensors to determine the current minimum, maximum, latest (last), mean, median, range and sum of their collected states. It doesn’t find the minimum of a single sensor or the minimum over time.
For a sensor that tells you the minimum daily value of two sensors you have a couple options.
For each source sensor, a Statistics sensor to find its minimum over the last 24 hours. Then, add a Template sensor to find the minimum of those two.
A trigger-based template sensor can be used to get the current day’s minimum from multiple source sensors.
template:
- trigger:
- platform: time
at: "00:00"
- platform: state
not_to:
- unknown
- unavailable
entity_id:
- sensor.example_1_temperature
- sensor.example_2_temperature
- name: Daily Min Temperature of 1 and 2
unique_id: daily_min_temp_1_2_001
unit_of_measurement: "°F"
state: |
{% set source = expand(
('sensor.example_1_temperature',
'sensor.example_2_temperature')
| select('has_value'))
| map(attribute='state') | select('is_number') | map('round', 1) | min %}
{% if trigger.id == 'reset' %}
{{ source }}
{% else %}
{% set current = (this.state or trigger.to_state.state) | float %}
{{ [source, current] | min }}
{% endif %}
