I’ve created a helper to change a shelly UNI Plus counter towards a water class (L) to be used in the energy board. Now, sometimes, this counter drops to 0, what gives a huge amount of water usuage. Any idea what I’m doing wrong?
The counter itself:
The helper:
The result in the energyboard:
This is my template:
{{ states('sensor.waterpomp3000l_counter_value') | float(0) }}
tom_l
November 17, 2024, 11:25am
2
Why are you using a helper at all?
All you are doing is copying the state value.
If you do have a reason then this is the bit you need to remove to prevent the drops to 0:
|float(0)
I´ve made the helper to convert the shelly sensor (sensor.waterpomp3000l_counter_value) to a water class. So I can use that on the energy board.
tom_l
November 17, 2024, 8:16pm
4
You don’t need a template sensor to add a device class. Just do this:
configuration.yaml
homeassistant:
# there may be other stuff here, but add the following (noting the indentation):
customize: !include customize.yaml
Then in customize.yaml
sensor.waterpomp3000l_counter_value:
device_class: water
state_class: total
# other entities to customize can be added to this file.
See: https://www.home-assistant.io/integrations/homeassistant/#manual-customization
Just for my understanding.
Any pro/cons between the customer.yaml or helper method?
Guess with the helper method, I’m having an entity extra?
tom_l
November 18, 2024, 8:02pm
6
Yeah basically that’s it, no unneeded duplication.
