I am trying to determine the min and max value of my windspeed sensor using Helper Function.
The aim is to get min max values for one day, but unfortunately both values (min-max) are identical.
In Min/Max Sensor does work was the Answer: At least two entities to monitor
but i have only one speed sensor.
Because, that is not the correct integration for what you are trying to do. If you just want to be able to see the daily min or max in the frontend, you can use a Statistics card. If you want the value available for automation or other purposes you need a Statisitcs sensor like:
Sorry, I had a typo. The precison: variable defines the number of decimal places of the calculated sensor value that will be displayed. It should be precision: 1.
