I have a number of Shelly switches in Home Assistant and some of them are controlling lights, so I used the helper ‘switch as light’. This has worked perfectly until 2024.8.
The switches still work without any issue, but the helper shows “unavailable”. I deleted one and recreated it, same problem.
I don’t see any error messages in the log about this either.
Any idea?
My old school works perfekt
Yaml Code
switch:
switches:
rgbw2_195:
unique_id: rgbw2_195_0000000000
value_template: "{{ is_state('light.rgbw2_195', 'on') }}"
turn_on:
service: light.turn_on
entity_id: light.rgbw2_195
turn_off:
service: light.turn_off
But in the new Version from HA you can create a template switch helper
I have the same issue here, all philips bulbs (via zigbee zha) are not working anymore!
EDIT:
Found the fix:
Reload ZHA
It turns out my Mosquitto server was down as well and couldn’t start because port 8884 wasn’t available. I had to reboot the Home Assistant VM and then all problems were solved. Apparently the update to 2024.8 left some thing unfinished.
