Helper - View list of automations/scripts in which it is used
On a device, you can see which automations or scripts that device is used in. Can we have the same for Helpers? It would be great to be able to see which automations or scripts that helper is used in.
This would be helpful if you change something about the helper and need to make sure your automations/scripts involving that helper are up to date. Also, it’d be useful for cleaning up helpers you may no longer need - it would let you check that a helper is not being used in anything before you delete it.
Saw this thread which is similar but didn’t see anything quite like what I was looking for. similar.WTH isn't there a way to find all orphaned helpers no longer in use?
This is an Input Boolean helper named “Test”.
Click the gear icon, then click Related.
It shows it is used in an automation named “Test xyz”.
Lifesaver… Thanks for showing me!
