I have several helpers that are dates, and I have one dropdown to determine a part of the helper name to gain the correct date. That probably sounds over-complicated.
Here is generally the syntax that I am looking for to figure out if the current time is greater than the value of one of my helpers. This works fine:
{{ now().timestamp() > state_attr('input_datetime.camera_wait_date_front','timestamp') }}
The problem is that instead of hard-coding the name of the camera 'front" as above, I have another dropdown helper that contains the correct camera name (in this case “front”). I tried many combinations of the statement below, and I just can’t figure out how to use the dropdown to determine the name of the correct date/time helper. Here’s what I tried:
{{ now().timestamp() > state_attr('input_datetime.camera_wait_date_(states('input_select.camera_current_cam_name_dropdown'))','timestamp') }}
Any help sincerely appreciated.
