Hi, I’ve created a Helper Group (type switch) and inside it there are 4 switch entities.
I created a lovelace button that toggles helper group entity.
It works but not toggles all entites in the group. It do it, seams, in random way.
Am i wrong something?
regards
Is hiding the members activated?
Hi, was not. Anyway enabling it doesn’t change anything
You don’t want it activated.
Nothing changing. Either is activated or not
I tested the switch group helper and had no issues. Can you post your lovelace button code?
show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.emule_on_off
icon: mdi:donkey
show_state: false
Toggle only works if the switches inside the group have a state associated with them.
Solved!
Initial solution (Groups) was good. Issue was given by triggered entities. If started all togheter (pfsense integration) for some reason doesn’t work. Created a script that wait 2 s between one action and other and now it working good.
Hi, I am also running into this issue. Would you mind sharing your script with me, please?
