hi,
I have a question about helpers in home assistant.
Is it possible to reset a helper after a period of time for example a switch
hi,
If I understand correctly your question, yes you can by using automation, you can reset (toogle) a switch in a specific state for a defined time.
automation:
- platform: state
entity_id: switch.office
# Must stay "on" for 30 seconds
to: "on"
for: "00:00:30"
- service: switch.toogle
FYI, helpers in home assistant are: input_booleans, input_datetime, input_numbers, input_text, input_dropdown, counter and timer.
thank you for youre response.
But the automation doesn’t work for helpers.
What do you mean by “doesn’t work”, you can have an automation like this with input_boolean:
automation:
- platform: state
entity_id: input_boolean.office
to: "on"
for: "00:00:30"
- service: input_boolean.toggle
thanks, it works now.
switch —> boolean.
