Good evening
I have been working on trying to use these Heltec Touch Modules as a switch input for a sonoff basic. Im afraid i have not had any luck getting this to work. The module as 3 pins, VCC, GND, and out. Input voltage on the module is 3.3v and the output through the “out pin” is 3v as well. When I wire this to GPIO 14 and assign this pin as any switch or button in the tasmota SW, nothing happens. Any Ideas or suggestions?
I am experimenting with these touch modules on a Wemos D1 Mini Pro (ESP8266), and had to add a pull-down resistor (10kΩ) between the touch module’s out and GND to make it work.
Not sure how that relates to a Sonoff Basic though.
yeah I think I tried that, but will try again. THank you
yep this worked for me also! Thanks!
Doesn’t work for me
Just try to get it running but my (standard) button code doesn’t recognize any input? The button color is switching nicely and I have 10kohm between OUT and GND.
Any tips?
