Heltec WiFi Kit 32 V3 shown as unknown board
i am a beginner with coding
and this is my first try with homeassistant
i wrote a small code for a watersensor in arduino IDE:
#define POWER_PIN  2 // ESP32 pin GPIO2 connected to sensor's VCC pin
#define SIGNAL_PIN 1 // ESP32 pin GPIO1 (ADC0) connected to sensor's signal pin
int value = 0; // variable to store the sensor value
void setup() {
  Serial.begin(9600);
  pinMode(POWER_PIN, OUTPUT);   // configure pin as an OUTPUT
  digitalWrite(POWER_PIN, LOW); // turn the sensor OFF
void loop() {
  digitalWrite(POWER_PIN, HIGH);  // turn the sensor ON
  delay(10);                      // wait 10 milliseconds
  value = analogRead(SIGNAL_PIN); // read the analog value from sensor
  Serial.print("The water sensor value: ");
  Serial.println(value);
  delay(1000);
and it worked as intended
when the sensos comes in contact with water it gives a readout
then withoud changing the wireing i mage a yaml file:
esphome:
  friendly_name: Watersensor
esp32:
  board: heltec_wifi_kit_32_V3
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXX"
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-830490"
    password: "sn3pbzDwbTyP"
captive_portal:
# Add the water sensor configuration
  - platform: adc
    pin: GPIO1  # Change this to match the GPIO pin you're using for the signal pin of the water sensor (e.g., GPIO1)
    update_interval: 1s  # Adjust the update interval as needed
    filters:
      - lambda: |-
          if (x < 10) {
            return 0.0;  // Adjust this threshold to match your sensor's readings
          } else {
            return x;
    unit_of_measurement: "units"  # Change to the appropriate unit
    icon: "mdi:water"
    attenuation: 0db  # Add this line to set the ADC attenuation to 0db
    id: water_sensor  # Add an ID to the sensor for later reference
output:
  - platform: gpio
    pin: GPIO2  # Set this to the GPIO pin you used for Vcc (e.g., GPIO2)
but i get an errormessage in the line
This board is unknown, please set the variant manually.
i used the ID from:
https://docs.platformio.org/en/latest/boards/espressif32/heltec_wifi_kit_32_V3.html
so i dont know what i am doing wrong
What version of esphome?
i’m using ESPHome version: 2023.8.2
Try a lowercase v
wifi-kit-32-v3
See https://github.com/platformio/platform-espressif32/blob/eb7eba46fdc46730bc689888a0daf6234ff4febe/boards/heltec_wifi_kit_32_V3.json
Must say I am not entirely sure, it is just a guess.
did not work
i tried:
wifi-kit-32-v3
heltec_wifi_kit_32_v3
heltec-wifi-kit-32-v3
heltec-wifi-kit-32-V3
Sorry, my mistake, try underscores _ not hyphen -
board: wifi_kit_32_v3
gives the same error
when i use the id from another board the code shows no errors.
i tried it with a couple of the ID’s from baords with an ESP32S3 MCU
Just try it with this code:
esp32:
  variant: esp32s3
  framework:
    type: arduino
    version: 2.0.9
    platform_version: 6.3.0
Works perfect for me :slight_smile:
