Hi ! Tried to add the Heltun HE-HLS01 in relay mode found some wierd issues above the fact that it doesnt work.
[44-112-0-16] Temperature Scale set to Celcius … but the:
[44-49-0-Air temperature] Air temperature in Multilevelsensor v11 shows temp in Farenheit. But in the card it shows in celcius. -
Tried to set: [44-112-0-152] Temperature Rise Notification to default value of 1 , returns to 34
and the parm 153 of seems strange to. -
[44-50-0-value-65537] Electric Consumption [kWh] shows a value of 9.98 kWh after very short time of forced connection. (200W floor heating.) something is very odd here …
If I activate the “RestRoom-RestRoomFloorHeating_Switch” it turns on and almost direct to off state.
I can activate the switch via the [44-112-0-7] Relay Output Mode to normally closed
Any ideas …
Regards …
Stefan
