I’ve installed a HELTUN thermostat to control my bathroom’s underfloor heating. It has both an air and floor thermometer, however the thermostat is positioned outside of the room, so I would like to use the floor temperature.
In Home Assistant, the HELTUN appears as a thermostat and provides a sensor for both the air and floor temperatures. I’ve disabled the air temperature sensor, however when I use the thermostat card in the Overview it defaults to the air temperature, and I can’t figure out how to change that. I’ve configured the thermostat to use the floor temperature for controlling the temperature, but that setting doesn’t seem to affect what Home Assistant displays.
Is there a way I can tell Home Assistant which temperature sensor to display for the thermostat? I’m aware of the Generic Thermostat entity, but that seems to be for turning a switch into a thermostat, and since the HELTUN has multiple modes and stuff, and it doesn’t really seem setup to be a “pretend to be this thermostat but display this temperature sensor” entity.
