Here is a example of samsung heatpump conversions when using wifi-kit and smart things integration
This is an working solution using climate_template and you would like to convert water_cooler to climate entity in order to show it on UI:
## SmartThings integration Heat pump Boiler conversion to climate template
- platform: climate_template
  unique_id: samsung_boiler
  modes:
    - "heat"
    - "off"
  preset_modes:
    - "eco"
    - "home"
    - "comfort"
    - "boost"
  min_temp: 30
  max_temp: 50
  temp_step: 0.5
  current_temperature_template: "{{ state_attr('water_heater.boiler', 'current_temperature') }}"
  target_temperature_template: "{{ state_attr('water_heater.boiler', 'temperature') }}"
  hvac_action_template: >
    {% set mode = state_attr('water_heater.boiler', 'operation_mode') %}
    {% set valve = states('sensor.soojuspump_klapi_asend') %}
    {% if mode == "off" %}
      {% set status = "off" %}
    {% elif valve == "room" %}
      {% set status = "idle" %}
    {% elif valve == "tank" %}
      {% set status = "heating" %}
    {% endif %}
    {{ status }}
  hvac_mode_template: >
    {% if mode in ("unavailable", "unknown", "off") %}
    {% elif mode in ("eco", "heat_pump", "performance", "high_demand") %}
      {% set status = "heat" %}
    {% endif %}
    {{ status }}
  preset_mode_template: >
    {% if mode in ("unavailable", "unknown") %}
      {% set status = "eco" %}
    {% elif mode == "heat_pump" %}
      {% set status = "home" %}
    {% elif mode == "performance" %}
      {% set status = "comfort" %}
    {% elif mode == "high_demand" %}
      {% set status = "boost" %}
    {% elif mode == "eco" %}
    {% endif %}
    {{ status }}
  set_hvac_mode:
    - service: water_heater.set_operation_mode ## for Samsung boiler
        entity_id: water_heater.boiler
        operation_mode: >
          {% set mode = hvac_mode %}
          {% set state = "off" %}
          {% elif mode == "heat" %}
            {% set state = "heat_pump" %}
          {% endif %}
          {{ state }}
  set_preset_mode:
        entity_id: water_heater.boiler ## for Samsung boiler
        operation_mode: >
          {% set mode = preset_mode %}
          {% if mode == "eco" %}
            {% set state = "eco" %}
          {% elif mode == "home" %}
          {% elif mode == "comfort" %}
          {% set state = "performance" %}
          {% elif mode == "boost" %}
            {% set state = "high_demand" %}
          {% endif %}
          {{ state }}
  set_temperature:
    - service: water_heater.set_temperature ## for Samsung boiler
        temperature: "{{ temperature }}"
here is a example of converting the samsung heatpump into new climate_template to give hvac actions on the UI to follow the same behaviour as the water_heater:
## Samsung Heat Pump conversion to custom climate_template
  unique_id: samsung_heat_pump_adjusted
  name: Samsung Soojuspump adjusted
  modes:
    - 'off'
    - 'auto'
    - 'cool'
    - 'heat'
  min_temp_template: "{{ state_attr('climate.samsung_soojuspump', 'min_temp') }}"
  max_temp_template: "{{ state_attr('climate.samsung_soojuspump', 'max_temp') }}"
  temp_step: 0.5
  hvac_mode_template: "{{ states('climate.samsung_soojuspump') }}"
  current_temperature_template: "{{ state_attr('climate.samsung_soojuspump', 'current_temperature') }}"
  target_temperature_template:  >
    {% set mode = states('climate.samsung_soojuspump') %}
    {% set temperature = state_attr('climate.samsung_soojuspump', 'temperature') %}
    {% if mode == 'auto' %}
      {% set temperature = unavailable |float %}
    {% elif mode == 'off' %}
    {% endif %}
    {{ temperature }}
    {% set temperature = state_attr('climate.samsung_soojuspump', 'current_temperature') | float(0) %}
    {% set target = state_attr('climate.samsung_soojuspump', 'temperature') | float(0) %}
    {% set status = none %}
    {% if mode == 'heat' %}
      {% if temperature > target or valve == 'tank' %}
        {% set status = 'idle' %}
      {% else %}
        {% set status = 'heating' %}
      {% endif %}
    {% elif mode == 'cool' %}
      {% if temperature < target or valve == 'tank' %}
      {% else %}
        {% set status = 'cooling' %}
      {% endif %}
    {% elif mode in ['off', 'auto'] %}
    {% endif %}
    {{ status }}
  set_hvac_mode:
    - service: climate.set_hvac_mode
        entity_id: climate.samsung_soojuspump
        hvac_mode: "{{ hvac_mode }}"
  set_temperature:
    - service: climate.set_temperature ## for Samsung boiler
In this example I used smart things integration and my heat pump is connected to internet using the samsung wifi-kit
This is the result I got:
In off mode and Auto mode the temperature setpoint is not shown and setpoints cannot be adjusted
The Home and Away buttons are made with custom:button_card using some helpers and automations
