With hass 0.99 you can select events as triggers in the automation gui. This will simplify how you select your different remote control triggers
Thank you Kenneth, works well.
Thanks, after a little trying and failing I got this to work perfect
Using 254/-254 on both “bri_inc” and “transitiontime” got me the smoothest results.
Now, can I use my arrows like a color-wheel or somthing?
kind of found a way, even if I don’t realy understand the values yet.
"data": {
"hue": 10,
"transitiontime": 100
"entity": "light.zigbee_soverom",
"field": "/action"
https://dresden-elektronik.github.io/deconz-rest-doc/lights/
@KennethLavrsen thanks for sharing! What is the reason you create a group in Deconz instead of a light group in HA?
You’re using the same event (1002) for both ‘Turn On Bedroom from dimmer normal’ and ‘Turn On Bedroom from dimmer bright’, is that correct ?
The reason for using a Deconz group is that the deconz.configure service only works on either deconz lights or deconz groups.
No it is not correct. I made a mistake which I later had to correct. The dimmer bright event code should be 1001 and not 1002. I will correct my posting
Looks good!
I didn’t have the patience to figure this out when I set up our dimmer this spring so I just used the Deconz/Phoscon GUI. Might give this a try though. Thanks for sharing!
I created an AppDaemon app that uses the Philips Hue Dimmer switch and applies this method for smooth dimming of the lights. It also adds the possibility to turn on/off other devices or make a service call when a button is pressed. In case someone is interested:
I´ve an Ikea Dimmer Switch Type E1743. On/Off works fine after I followed this tutorial. But how to dimm with this one? I already figured out the events for dimming an stop signals but cant get it to work.
What are you missing, it’s all right there. Can you show your current code please?
My code is the same as in the example. I get it yesterday also working with the 5 Button remote. Only the Dimmer Switch does not work at dimming.
I guess he needs a little adjustment.
switch_work_light_decrease_brightness.yaml
# Reduces the brightness of the worktop lighting.
# Devices:
# Type: "Ikea Tradfri"
# - Dimmer Switch
# - Transformer
alias: worklight_dimmer_lights_decrease_brightness
initial_state: "on"
platform: event
event_type: deconz_event
event_data:
event: 2001
- service: deconz.configure
entity: group.ku_group_work_light
field: "/state"
data: { "bri_inc": -254, "transitiontime": 50 }
switch_work_light_increase_brightness.yaml
# Increases the brightness of the worktop lighting.
# Devices:
# - Dimmer Switch
# - Transformer
alias: worklight_dimmer_lights_crease_brightness
initial_state: "on"
platform: event
event_data:
event: 1001
field: "/state"
data: { "bri_inc": 254, "transitiontime": 50 }
switch_work_light_off.yaml
# Switches the worktop lighting off.
# Devices:
# - Dimmer Switch
# - Transformer
alias: worklight_dimmer_lights_off
initial_state: "on"
platform: event
event_data:
event: 2002
- service: light.turn_off
entity_id: group.ku_group_work_light
switch_work_light_on.yaml
# Switches on the worktop lighting.
# Devices:
# - Dimmer Switch
# - Transformer
alias: worklight_dimmer_lights_on
initial_state: "on"
platform: event
event_data:
event: 1002
- service: light.turn_on
brightness_pct: 100
switch_work_light_stop_brightness.yaml
# Stops the dimming of the worktop lighting.
# Devices:
# - Dimmer Switch
# - Transformer
alias: worklight_dimmer_lights_stop_brightness
initial_state: "on"
- platform: event
event_data:
event: 1003
- platform: event
event_data:
event: 2003
field: "/state"
data: { "bri_inc": 0 }
edit: I also tried "field: “/state” and "field: “/action”
The deconz.configure service works only with deconz lights or deconz light groups, it does not work with groups created in home assistant.
Also note “field” must be “/action” if it is a light group and “/state” if it is a single bulb.
If you did not already create groups in phoscon, do this and then use these groups instead of “group.ku_group_work_light”. Groups created in phoscon exposed to home assistant will start with “light.” and the attribute “is_deconz_group” is true.
Thank you. Now it works!
Is there any way to do this with regular Home Assistant switch?
I have a Deconz switch but a EspHome light.
No. This works only with deconz lights as the service is only available for deconz. Check out this app from @xaviml, it should cover your needs.
Do someone knows how to translate all these code in Node Red (if possible) ?
I use deconz and i didn’t even bother with all the automations. I just use the Phoscon app to allocate dimmers to the light groups and do it that way.
If you are using Deconz you might and just want to dim hue globes that is easier.
Obviously if you want your hue dimmer to control non-zigbee lights, then the automations are needed.
I made an update of my original post above showing how to do the same function using the new HA version 0.113 automation features. Now you can do is all with one automation which makes it simpler to overview and maintain.
Since I posted my original post I have put all HA config on github. You can find more examples there using the dimming method with deconz
