Whisper log
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name=‘Task-13394’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError(‘Connection lost’)>
File “/usr/local/lib/python3.9/dist-packages/wyoming/server.py”, line 35, in run
if not (await self.handle_event(event)):
File “/usr/local/lib/python3.9/dist-packages/wyoming_faster_whisper/handler.py”, line 45, in handle_event
await self.write_event(self.wyoming_info_event)
File “/usr/local/lib/python3.9/dist-packages/wyoming/server.py”, line 26, in write_event
await async_write_event(event, self.writer)
File “/usr/local/lib/python3.9/dist-packages/wyoming/event.py”, line 114, in async_write_event
await writer.drain()
File “/usr/lib/python3.9/asyncio/streams.py”, line 387, in drain
await self._protocol._drain_helper()
File “/usr/lib/python3.9/asyncio/streams.py”, line 190, in _drain_helper
raise ConnectionResetError(‘Connection lost’)
ConnectionResetError: Connection lost
INFO:wyoming_faster_whisper.handler:
future: <Task finished name=‘Task-13667’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError(‘Connection lost’)>
future: <Task finished name=‘Task-13759’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError(‘Connection lost’)>
future: <Task finished name=‘Task-13760’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError(‘Connection lost’)>
future: <Task finished name=‘Task-14587’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError(‘Connection lost’)>
future: <Task finished name=‘Task-14588’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.9/dist-packages/wyoming/server.py:28> exception=ConnectionResetError(‘Connection lost’)>
