Did it get moved?
I just updated to the new OS and the 0.105.2 patch…
Try a Reboot.
Four times now… No Joy!
Could be the user your login on with is not admin
Nope… only have one log in…
Thanks all for the help!
Do you have the app on your phone
Do you have Developer Tools or Supervisor visible? Notifications? They are all down the bottom with Configuration - your screenshot appears to show only the top half, or is that all you have?
Do you have “config:” explicitly listed in your configuration.yaml?
All are visible… You have to expand the image above to see them… But only the Developer tools and supervisor links are available… config: has never been in my configuration.yamal… but I do have ‘default_config:’
I just tested @brahmafear suggestion, and you DO now require config: in your file for Configuration to appear. Wasn’t listed in breaking changes, but definitely required now. Add it and you should be fine.
IDK, bitviper’s situation seems like something is off. Default_config: is supposed to include config:… unless they changed what integrations are loaded with default_config:.
That’s what I thought!
My two ecobee thermostats are also “Unavailable” but I think that’s most likely something else…
Sometimes I really Hate HA!
The same thing happened to me today.
From what I understand, there’s a chance a token refresh was in process when you applied the update. At least, that’s how I understand the issue. Here’s a link:
https://github.com/home-assistant/home-assistant/pull/28296#
The fix is to delete the integration and get a new 4-character code from the ecobee site, then reintegrate it. You should be able to leave your configuration.yaml file and API key intact.
It took a bit of fumbling for me to get the integration going again. I was being cautious not to accidentally disturb the app. I captured some notes, but hesitate to post them because they were written after the fact.
default_config does include config. I don’t have config in my configuration
Yep… that fixed the ecobee problem… Thanks Rob!
BTW the configuration came back w/o me doing a thing… go figure!
